Old 11-22-2012, 08:59 AM   #1
BRZnut
Drives: BRZ DGM Limited
Does the ride quality change with time??
My BRZ handles like a dream, but this is the first sports car I've had with low profile tires/sport suspension. I find the suspension slightly harsh (can feel every road imperfection, which we have alot of in NJ).Tires set at 36 psi.
Only have 100 miles on the car and wondering if those with more miles have noticed any less "harshness" with time??
No flames please...like "you should have gotten a minivan instead" !
Old 11-22-2012, 09:41 AM   #2
UPSed
UPSed's Avatar
Drives: FRS
Not gonna change anytime soon unless you find softer springs. The car is made to handle.
UPSed is offline   Reply With Quote
Old 11-22-2012, 09:44 AM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Technically it will get softer with time as everything wears down, bushings, shocks, the chassis, etc...
Will you be able to feel it? Maybe in 100 000 miles lol
Rayme is offline   Reply With Quote
Old 11-22-2012, 09:51 AM   #4
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
My BRZ was pretty "bouncy" over certain types of road bumps at first. Over the next several hundred miles it settled down. I think the BRZ has an amazing mix of suspension tuning. It has that buttoned down feel that BMW's used to have, never soft but never crashy.
This car continues to amaze me. Now at 5,750 miles and just enjoying the heck out of it on every drive.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 11-22-2012, 10:58 AM   #5
BRZnut
Good to know that it does settle down a bit. I have to agree, the handling and road feel is fantastic and just as good, if not better, than the reviews!
The more I drive it, the more I want to drive it again!
Old 11-22-2012, 01:57 PM   #6
ericvanderwoodsen
ericvanderwoodsen's Avatar
Drives: 2013 SWP Subaru BRZ Premium
It kinda depends on what car you came from, I came from a luxury car to my brz and it felt like a i was driving on third world country roads. After only 2k miles i've noticed i dont even really notice it anymore,
ericvanderwoodsen is offline   Reply With Quote
Old 11-22-2012, 02:05 PM   #7
Squishy
Drives: 2013 WRB BRZ
To be honest this should have been a consideration in purchasing your vehicle. You buy what works best for where you drive. A sports car will need smoother roads due to what it is engineered towards (road feel) such that imperfect roads will be the Achilles heel for any driving pleasure. Otherwise it is still a wonderful car just maybe not a good DD for you. One solution might be to go with 16" wheels and taller tires as this would smooth out daily driving alot. Then you could put back the stock tires for fun days. Tires will smooth out most bumps and taller tires will cushion the bumps alot - maybe not totally considering the stiffer springs and shock valving. However do remember tires make the most immediate improvement to any "feel" one might get from a vehicle.
Squishy is offline   Reply With Quote
Old 11-22-2012, 05:14 PM   #8
fistpoint
Drives: Supercharged Golf Cart
My RSX-S started showing signs of suspension wear at 50k. By 80k you definitely wanted to replace the struts to have the original feeling maintained. If you don't replace them then you get a bouncy ride.
I imagine the same applies to this or any sporty car with a tight suspension.
fistpoint is offline   Reply With Quote
Old 11-23-2012, 12:24 AM   #9
chaotichoax
chaotichoax's Avatar
Drives: 2013 SWP BRZ
Tire choice has a lot to do with the feel as well. I recent put on the some General winter tires and the sidewalls have a lot of flex which you can feel in the handling of the car. The car is a little more willing to get sideways on dry, cold pavement. Put that's the sacrifice I'm willing to make for moderate snow capability.
chaotichoax is offline   Reply With Quote
Old 11-24-2012, 01:19 AM   #10
JohnS_Rosamond
Drives: Mazda MX5
Tire pressure and sidewall section height (as well as tyre type) will influence how soft or harsh the ride is - as well as teh suspension. I can't remember what the section height is, but for example if you have a 205/45R-17 then a 205/50R-17 might ride a little softer, but it may affect the handling also depending on how strong the sidewall is. BRZ has slightly softer shocks in the rear more stiff in the front. When they need replacing you may want to put the OEM FR-S shocks in the front as they are valved a little softer. However, anything you do to change the ride will also affect how the car handles. If you wanted a softer ride to fit the local roads, perhaps the BRZ wasn't the best fit. I drive a Miata and I feel like the BRZ is a little softer riding (but that may hanve more to do with overall chassis size and weight).
JohnS_Rosamond is offline   Reply With Quote
Old 11-24-2012, 02:20 AM   #11
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Some adjustable dampers, like Bilstein or Koni, with the stock springs may be more comfortable. I find the stock setup pretty good though.
uspspro is offline   Reply With Quote
Old 11-24-2012, 12:15 PM   #12
FT_Monk
Drives: Over the hill WRX
You set the tire pressure at 36 psi and you want comfortable?
FT_Monk is offline   Reply With Quote
Old 11-24-2012, 04:47 PM   #13
jflogerzi
jflogerzi's Avatar
Sorry sir. You bought a sports car and it comes with the territory. Different tires and softer springs, but if you do this, it begs the question. Why did you buy a sports car?
Old 11-24-2012, 05:08 PM   #14
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Minivans ride like shit.
Go back to school, get a good job and buy a Rolls Royce.
Your welcome.
Ditch the family while your at it, waste of money.
Gas Quality Bonburner Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 03-04-2013 08:55 PM
ISIS Catback quality? lbroskee Engine, Exhaust, Transmission 19 12-03-2012 11:25 PM
Time for the second oil change yet? ProTekk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 11-16-2012 03:13 PM
Lowest quality spring? Synack Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 07-26-2012 12:00 PM
