#15 | |
Drives: Firestorm 2013 FR-S
Isn't this "low oil" the same story as the engines with the ruined 4th bearings caused by the cam advance mechanism failure? Was the cam advance mechanism OK in your car? I usually do my own oil changes, but with this car the $tealer changes might be worth it.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#16 |
Dismember
Drives: 2013 Red Scion FR-S
My local dealership does the change for less than the quickie places charge for synthetics.
#17 |
Drives: 2013 LMT BR-Z
They claimed your "own" oil changes clears them of all liability and warranty claims. They want documented proof of the oil changes and receipts. Thus why I had to file the lawsuit.
#18 |
SLO NO MO
Yeah, if you guys want to have no headaches with warranty work, have the dealer do all scheduled maintenance. You're asking for trouble otherwise as they will always first assume that whatever failed happened because of someone else's incompetence. Or just go FI as soon as you get the car and forget you even had a warranty. Then you can do all your own oil changes without worry and just buddy up with a local mechanic who won't rape you for the bigger stuff. That's the route I took.
As for the OP - I'd see if another dealer in the area would be willing to work with you. Definitely don't go back and do business with someone you had involved in a suit. That's just asking for even more problems down the road. I can't imagine why another dealer not associated with this mess would turn away work and money unless Subaru itself has put you on some kind of blacklist, and if so, perhaps another lawsuit is in order. |
#19 |
Drives: 13 FRS Satin
Has anyone narrowed it down to what is causing the oil starvation?
http://www.motoiq.com/MagazineArticl...From-King.aspx Since we know that the oil starvation in the EJ was down to design, they popped up not too long ago. |
#20 | |
Drives: '13 FRS - STX
At least those are the three concerns I've seen voiced with the lubrication system of the FA20. |
#21 | |
But I guess they COULD say the non-dealer mechanic that did the change messed up and you need to sue him. That would be really uncomforable for most people, who have some kind of relationship with their mechanic. It might be worth consulting a lawyer re this-- if so most manufacturers could deny coverage to most of their customers with slightly older cars.
#22 | |
#23 |
SLO NO MO
The problem, as described by the OP, is that Subaru has taken the stance that he has one oil change interval that was not performed by the dealership, so they are taking the stance that the oil starvation was caused by that oil change. Of course, the burden of proof is on them to show that, but as evidenced by the OP's experience, lawyers did have to get involved. So yes, while we as consumers have rights clearly laid out in writing, they can still make life pretty miserable for you by claiming failure was caused by improper maintenance since they didn't do it.
| The Following User Says Thank You to Foobar For This Useful Post: | strat61caster (03-11-2015) |
#24 | |
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
#25 | |
#26 |
#27 | |
There are a lot of potential causes for this, we're chasing oil because that's what dealerships have mentioned in warranty repairs, that doesn't mean that's the root cause. Especially since the claim is that the oil pump is blocked causing low oil flow, why is the oil pump blocked? Debris, debris that likely came from the failed bearing, what caused the failed bearing? Lack of oil flow? Maybe. |
#28 |
Drives: BRZ DGM Limited
So many questions and so few answers as to what the problem is...
| The Following User Says Thank You to BRZnut For This Useful Post: | marky (03-12-2015) |
| Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5 | CSG Mike | Issues | Warranty | Recalls / TSB | 909 | 09-15-2016 10:31 AM |
| Seized brake rotor removal tool | fstlane | DIY (Do-It-Yourself) Guides | 15 | 09-06-2015 12:38 AM |
| Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
| Time to build a motor, what options have others found? | Cross | Forced Induction | 188 | 11-25-2014 10:10 AM |
| Blown / Seized Engines Fixed in MY14? | iLuveKetchup | Issues | Warranty | Recalls / TSB | 28 | 10-24-2013 10:42 AM |
