Old 06-28-2014, 03:35 PM   #1
fstlane
fstlane's Avatar
Drives: BRZ Limited
Seized brake rotor removal tool
While replacing my wheel studs I discovered my rotors were stuck and I didn't have the correct size bolts on hand to remove them. I found the spare tire hold down bolt is the correct size and makes the perfect tool for the job!
fstlane is offline   Reply With Quote
Old 06-28-2014, 03:37 PM   #2
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
nice "life hack" or whatever the kids call it these days. I like when odd things work out like this.
Old 06-28-2014, 04:01 PM   #3
White64Goat
Did you have the emergency brake on by chance?
Old 06-28-2014, 04:01 PM   #4
Reaper
Reaper's Avatar
Drives: violent
I was thinking the same thing, ha.
Old 06-28-2014, 04:24 PM   #5
fstlane
fstlane's Avatar
Drives: BRZ Limited
No, there was just rust built up at the rotor to hub seating surface.
Old 06-28-2014, 04:30 PM   #6
White64Goat
Old 07-20-2014, 09:48 AM   #7
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Savior
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 07-20-2014, 02:03 PM   #8
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Nice find!
When I did the brembo brake conversion, I had to take my bike to the parts store to get a couple of M8 x 1.25 bolts.. if only I had known about this back then.
Not sure if coincidence, or the engineers designed the spare tire tie-down bolt specifically with this in mind.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 07-20-2014, 03:20 PM   #9
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Nice find !
Old 07-20-2014, 10:08 PM   #10
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Did you try hitting the flat part of the rotor hat with a big hammer first?
Nice find, I may end up using this one day!
Old 07-21-2014, 12:10 AM   #11
fstlane
fstlane's Avatar
Drives: BRZ Limited
No, I tried a few light blows with a rubber mallet on the backside rotor face with no results. I then tried the tire bolt and both rotors pressed off easily with just a few turns of the handle.
Old 07-21-2014, 08:24 PM   #12
roddy
roddy's Avatar
Drives: '13 Ultramarine
Nice find! I keep a couple of metric bolts in the "tune-up" drawer just for that reason, but for those who don't, this is a good tip. Thanks for posting it up.
Old 09-05-2015, 10:09 PM   #13
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I tried this earlier today for the rear rotors, it worked but it fucked up the threads real nice. I suppose on Monday I'll be ordering a new one...
It's my fault and I'm by no means blaming the OP. I highly recommend grabbing a bolt from the front undertray instead, it's far stronger
Old 09-05-2015, 11:45 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I think it's designed this way lol. Did you know the screw driver in the trunk alone is all you need to take apart all interior? LoL
I noticed this when I was doing sound deadening and install OEM+ for my car.
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
e-brake removal, spacer to remove backplate puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-31-2014 06:48 PM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 02:39 PM
Radio removal tool brzing Electronics | Audio | NAV | Infotainment 1 07-13-2013 05:56 PM
Brake rotor differences between base and Sport-tech BRZ Sport-Tech CANADA 10 04-12-2013 07:15 AM
