Old 03-10-2015, 04:09 PM   #1
GWiZ
Drives: 2013 LMT BR-Z
Question Seized Motor - Need options/help
Ladies and Gentlemen,
I am in need of some rather quick assistance/advice... Long story short, I have a seized 2013 BRZ from lack of oil. Subaru refused to acknowledge the warranty, lawsuit ensued, and I am here. (With a check from Subaru of course)
Subaru refuses to touch the car now even though I'm willing to pay them for the repair that should have been done in September last year.
What are the best options? I have reached out to a few shops but I am not exactly sure what I "should" do in this situation.
Buy a new motor? Have the short block repaired and have them check the long block for any other damages? Finances aren't the biggest issue but I do not want to continually have to worry about the reliability of the vehicle once I've found a solution. I know there are some serious tinkers and brains on here so I value any input I can get.
Thanks in advance!!
GWiZ is offline   Reply With Quote
Old 03-10-2015, 04:19 PM   #2
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
If finances are not a worry and reliability is, engine swap a LSX or a 2JZ
Otherwise I'd build a FA20 with all new aftermarket internals so it be ready for boost later on the line
GotBRZ1691 is offline   Reply With Quote
Old 03-10-2015, 04:27 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would check the junk yards and throw in a good running used motor. Just call it a learning experience and move on with life.
Old 03-10-2015, 04:30 PM   #4
White64Goat
Search the junkyards for an engine........
Old 03-10-2015, 04:38 PM   #5
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
i'm with the rest, find a used engine from a wreck, swap that puppy in and move on.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 03-10-2015, 05:07 PM   #6
BRZnut
Drives: BRZ DGM Limited
Care to share any details of how the engine failed???
Old 03-10-2015, 05:45 PM   #7
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
If subaru is unwilling to work on your car, look up your local Toyota dealership. Sit down with the service manager and explain your situation and that you are willing to pay to have your motor repaired
LavosTRD is offline   Reply With Quote
Old 03-10-2015, 05:49 PM   #8
GWiZ
Thank you guys for the quick responses... Looks as though you are all right in getting a salvaged motor for a much quicker, cheaper turn around.
The cause of the seize was lack of oil. There was never an oil indication light and the discrepancy was with the maintenance record/proof of. Thus, where we were at a disagreement regarding who would pay for the repairs.
Old 03-10-2015, 05:51 PM   #9
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
built 10.5 compression ratio + 20 lbs of boost sounds delicious
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 03-10-2015, 07:42 PM   #10
BRZnut
I've heard that story around here from other members. Failure from "oil starvation" and if you don't have every oil change done at the dealer, even if you have proof it was done elsewhere, dealer blames the owner.
Glad it worked out for you in the end. But, I wonder instead of replacing with the same engine, which clearly has some issue with oil flow, maybe there are shops that can rebuild a more bullet proof engine?
Old 03-10-2015, 07:55 PM   #11
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
...and IMO, probably more trustworthy. I would definitely choose a factory-assembled engine over a "field-built" engine.
billwot is offline   Reply With Quote
Old 03-10-2015, 09:20 PM   #12
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Thanks in advance!!
Why are they denying your claim? Is your car heavily modified? Are you burning oil which led to the lack of oil? Did you have all your oil changes done at the dealership? If yes, then probably the technicians didn't add enough oil.
N1rve
Old 03-11-2015, 01:49 PM   #13
GWiZ
They were denying the claim due to a missing oil change that was done but apparently never documented Subaru. Thus questions whether it was done or done wrong. There was no leak, no signs of burning, etc. No heavy modifications added either.
The determining factor they didn't want to battle and agreed to settle was the fact the oil light never came on. Not when there was a little missing, a lot missing, or no oil period. I have proof from a reputable shop regarding that as well.
So new motor it is!
Old 03-11-2015, 03:00 PM   #14
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
I have a feeling doing my own oil change for the second change was a bad idea now..
Wilso is offline   Reply With Quote
Has anyone had a warranty claim denied? Seized engine! Pics of teardown added 6/5 CSG Mike Issues | Warranty | Recalls / TSB 909 09-15-2016 10:31 AM
Seized brake rotor removal tool fstlane DIY (Do-It-Yourself) Guides 15 09-06-2015 12:38 AM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 02:39 PM
Time to build a motor, what options have others found? Cross Forced Induction 188 11-25-2014 10:10 AM
Blown / Seized Engines Fixed in MY14? iLuveKetchup Issues | Warranty | Recalls / TSB 28 10-24-2013 10:42 AM
