Old 10-14-2014, 03:52 PM   #15
simpleisbest
Senior Citizen
Drives: Scion FR-S
I THINK that has to be the actual car ECU because those are injector cables, so all cars need them.
The four plugs connected to the actual ECM all start with A.
The only D plug that would have any such related engine stuff seems to be D48, which doesn't seem to be on the FR-S...
simpleisbest is offline   Reply With Quote
Old 10-14-2014, 03:53 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I give up
Old 10-14-2014, 03:54 PM   #17
simpleisbest
Senior Citizen
Drives: Scion FR-S
I give up
Thanks for trying!!
I am hoping that there may be a CANBUS converter out there. There exists such a product for other cars...not for ours specifically yet it seems, though...
The Following User Says Thank You to simpleisbest For This Useful Post:
Sportsguy83 (10-14-2014)
Old 10-14-2014, 04:10 PM   #18
coyote
coyote's Avatar
Drives: Slowly
Your best tach signal will come from the ignition. Cylinder 1 is from memory a blue and yellow wire, third from the right on the main ecm. Just probe it to check.
Sent from my Nexus 4 using Tapatalk
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
Old 01-18-2015, 01:24 AM   #19
ztan
Drives: Toyota 86
Originally Posted by JP View Post
seeing how no-one seems to be helping with your actual need, you can get the crimp terminals from RS Components online. I'm guessing if you use the Tyco part number you can find them at other retailers also.
The ECU connectors use the normal 025 and 040 terminals, pin 15 is an 025 size.
You may need to depin one of the existing pins to confirm the lock tabs match the datasheet, but this is the sort I see on the majority of late DBW Toyota and Subaru's with the 4 row header: http://au.rs-online.com/web/p/pcb-co...PSF_435696|acc
Tyco Part: 1123343-2
You can also buy repair terminals from Toyota/Subaru, but they're hideously expensive ($17-25ea for a single terminal crimped to a short length of wire)
Can anyone point to how to get connectors in and out of a ECU connector socket? I'm wanting to add a wire to pin 40 on connector 3C (DRL relay) which is empty.
ztan is offline   Reply With Quote
Old 01-18-2015, 03:13 AM   #20
steve99
Drives: FT86
I hope i am understanding your question correctly.
have not done these particular ones but generally the new pins just push in and have an angled barb that locks the pin in place. They can be a bit of a problem to get out, their may be a special tool but often you can slip a very thin screw driver like a jewelers one down the side of the pin where the locking barb is then pull the pin out.
54-Way Connector in Engine Bay MSEL Electronics | Audio | NAV | Infotainment 5 12-24-2013 01:58 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 02:13 AM
Third connector on headlights? FastLap Cosmetic Modification (Interior/Exterior/Lighting) 2 05-15-2013 02:36 AM
Help, what connector is this? Hayashi Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2013 02:39 AM
VSS Connector AlexTheGreek Engine, Exhaust, Transmission 15 02-02-2013 01:12 PM
