Senior Citizen
Drives: Scion FR-S
ECM Pin Connector
I'm looking to add a pin connector to one of the ECM harness sockets on my FR-S to pull RPM signal. I have read that the signal can be pulled from A35-15, yet for the USDM Scion FR-S, that location doesn't have a metal connector in that location (it's empty). I need to add a pin connector it seems.
Can anyone please tell me what size connector I will need to purchase that would properly fit? I'm practically clueless when it comes to this electrical stuff.
#2 | |
| The Following User Says Thank You to steve99 For This Useful Post: | simpleisbest (10-05-2014) |
#3 | |
Drives: 2015 FR-S (Halo)
Sent from my HTC One_M8 using Tapatalk
#4 | |
Senior Citizen
Drives: Scion FR-S
If there was a BT solution that would be awesome, but it seems that I need a real tach signal. With our CANBus systems, it seems that there are limited options. The A35-15 pin is located on the ECM (A35 plug is the 3rd plug from the top). It seems the slot is empty for the FR-S. There is a wire for BRZ with keyless, though. All I need to do is put a connector in that open slot and I will be able to pull the tach signal, it seems... |
#5 | |
http://www.ebay.com.au/itm/ifound-2n...item5d44202269 The information screen displays: 1. Speed: The number can indicate the current speed. 2. Rotation speed: indicates the rotating status of the engine and the scale measured represents the speed reached. 3. Water temperature: When the temperature reaches 100 degree centigrade, alarm will be given automatically with alarm light on. 4. Gear shifting reminding: It will remind the driver to gear up to save fuel when the engine speed and vehicle speed come to a certain ratio. 5. Overspeed reminding: the icon of overspeed will flicker and alarm when the vehicle exceeds the speed limit set up in advance. 6. Real-time one hundred kilometer/instantaneous fuel consumption: display fuel consumption of one hundred kilometers when the vehicle is moving, in L/100km. 7. Unit of kilometer/miles: in the international system of units, kilometer/hour & mile/hour are commonly used, in km/h & mph. 8. Battery voltage: when the battery voltage is less than/reaches 12V, the caution light will light up to remind the driver. 9. Buzzer mark: pressing the switch button can turn on or turn off the sound of the buzzer. Or this one that appears to do tyre pressures as well http://www.ebay.com.au/itm/HUD-Proje...item2592ac3de1 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
seeing how no-one seems to be helping with your actual need, you can get the crimp terminals from RS Components online. I'm guessing if you use the Tyco part number you can find them at other retailers also.
The ECU connectors use the normal 025 and 040 terminals, pin 15 is an 025 size. You may need to depin one of the existing pins to confirm the lock tabs match the datasheet, but this is the sort I see on the majority of late DBW Toyota and Subaru's with the 4 row header: http://au.rs-online.com/web/p/pcb-co...PSF_435696|acc Tyco Part: 1123343-2 You can also buy repair terminals from Toyota/Subaru, but they're hideously expensive ($17-25ea for a single terminal crimped to a short length of wire) |
| The Following 3 Users Say Thank You to JP For This Useful Post: |
#7 | |
Senior Citizen
Drives: Scion FR-S
| The Following User Says Thank You to simpleisbest For This Useful Post: | kmbkk (10-11-2014) |
#8 | |
First 86 Driver Baby!
Drives: FR-S, Flex
Senior Citizen
Drives: Scion FR-S
I got the wires with the female connectors, unfortunately once inserted into the plug to the ecm, no signal was detectable with a voltage reader. I think the previous posts by others about A35-15 being a source of a tach signal are false....
![]() If anyone has actually been able to pull tach signal on a USDM FR-S from this location, please let me know and I will try again!! |
#10 | |
I Love custom Turbo kits
Drives: Limited BRZ
http://www.ft86club.com/forums/showthread.php?t=28800
#11 | |
Senior Citizen
Drives: Scion FR-S
That's the thread I originally referenced and directed me to A35-15 for tach signal. Lonely Sushi claimed that he got tach signal from there, but we tried it here and no signal. Either his claim is bogus, or he neglected to add what other details he did to get signal. Regardless, I am not able to pull signal just by adding the proper female connector and a wire (as Lonely Sushi claimed). I even pm'd him for details, but got no response... Again, if there is another source of anyone successfully pulling tach signal from A35-15, please let me know!
#12 | |
Drives: Limited BRZ
#13 |
Senior Citizen
Drives: Scion FR-S
#14 |
Drives: Limited BRZ
I THINK that has to be the actual car ECU because those are injector cables, so all cars need them.
| 54-Way Connector in Engine Bay | MSEL | Electronics | Audio | NAV | Infotainment | 5 | 12-24-2013 12:58 AM |
| What's this connector ? | mashal | Electronics | Audio | NAV | Infotainment | 5 | 12-10-2013 01:13 AM |
| Third connector on headlights? | FastLap | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-15-2013 01:36 AM |
| Help, what connector is this? | Hayashi | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-26-2013 01:39 AM |
| VSS Connector | AlexTheGreek | Engine, Exhaust, Transmission | 15 | 02-02-2013 12:12 PM |
