Drives: BRZ Premium Black
VSS Connector
I'm trying to:
1) Locate the VSS connector 2) Identify the connector make and model I've assumed that it may be one of these two: ![]()
OK I answered #2 myself.
They are Yazaki 62 Z connectors. available from www.eaternbeaver.com or www.newunitedracingtech.com |
To be more precise here are the part numbers
Housing 62 Connectors Z Type Sealed Female 2 Light Gray 7123-8520-40 Housing 62 Connectors Z Type Sealed Female 2 Brown 7123-8521-80 Housing 62 Connectors Z Type Sealed Male 2 Light Gray 7222-8520-40 Housing 62 Connectors Z Type Sealed Male 2 Brown 7222-8521-80 |
| The Following User Says Thank You to AlexTheGreek For This Useful Post: | Sportsguy83 (01-29-2013) |
Why?
Drives: 2013 Subaru BRZ
Reasons:
1) VSS mod for the GPS unit 2) Speedometer calibration To elaborate on #2, when changing final drive ratio or tire diameter, the speedometer needs recalibrating. This can be achieved with a correction unit (http://12oclocklabs.com/). Do you know which of the two connectors in the picture is the VSS. The grey or the brown? Neither? They are located just above the bell housing. |
#7 | |
Drives: 2013 Subaru BRZ MT Limited
Most likely those two connectors you have are an engine RPM sensor and some other sensor like a clutch position sensor or something. Speed sensors are not usually located on the bell housing, they are usually located on the back of the transmission near the output shaft to measure the rotational speed of the drive shaft which is directly related to the speed of the car.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | AlexTheGreek (01-29-2013) |
#9 | |
Yeah you do not need to change anything when changing the final drive. Racecomp Engineering installed the Cusco 4.51 FD and did no changes, the speedometer is fine. |
| The Following User Says Thank You to xwd For This Useful Post: | AlexTheGreek (01-29-2013) |
#10 |
Since the speed is determined from the wheel speed sensors a final drive won't effect it, but a tire size change will.
#11 | |
Thats where the connectors sit, but the wiring goes down to the transmission area. I assume the BRZ does still have a speed sensor at the Transmission output shaft? |
#12 |
#13 |
Yes
| OBDII Connector | nzer | AUSTRALIA | 64 | 05-09-2013 02:44 PM |
| OBDII (OBD2) Connector | nzer | Electronics | Audio | NAV | Infotainment | 35 | 04-21-2013 12:36 AM |
| What type of connector is this? | boredom.is.me | Electronics | Audio | NAV | Infotainment | 1 | 01-20-2013 12:28 PM |
| brake light connector | kask2_6.0 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-28-2012 05:18 PM |
| iPhone 5 new connector & BeSpoke?!?!? | Davyator | Electronics | Audio | NAV | Infotainment | 14 | 09-18-2012 11:39 PM |
