| Software Tuning Discuss all software tuning topics. |
#15 | |
Senior Citizen
Drives: Scion FR-S
The only D plug that would have any such related engine stuff seems to be D48, which doesn't seem to be on the FR-S... |
#16 | |
I Love custom Turbo kits
Drives: Limited BRZ
#17 |
Senior Citizen
Drives: Scion FR-S
| The Following User Says Thank You to simpleisbest For This Useful Post: | Sportsguy83 (10-14-2014) |
#18 |
Drives: Slowly
Your best tach signal will come from the ignition. Cylinder 1 is from memory a blue and yellow wire, third from the right on the main ecm. Just probe it to check.
Sent from my Nexus 4 using Tapatalk |
| The Following User Says Thank You to coyote For This Useful Post: | Sportsguy83 (10-14-2014) |
#19 | |
Drives: Toyota 86
#20 | |
Drives: FT86
have not done these particular ones but generally the new pins just push in and have an angled barb that locks the pin in place. They can be a bit of a problem to get out, their may be a special tool but often you can slip a very thin screw driver like a jewelers one down the side of the pin where the locking barb is then pull the pin out. |
| 54-Way Connector in Engine Bay | MSEL | Electronics | Audio | NAV | Infotainment | 5 | 12-24-2013 01:58 AM |
| What's this connector ? | mashal | Electronics | Audio | NAV | Infotainment | 5 | 12-10-2013 02:13 AM |
| Third connector on headlights? | FastLap | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-15-2013 02:36 AM |
| Help, what connector is this? | Hayashi | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-26-2013 02:39 AM |
| VSS Connector | AlexTheGreek | Engine, Exhaust, Transmission | 15 | 02-02-2013 01:12 PM |
