Old 10-17-2014, 02:32 PM   #155
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by mkivsoopra View Post
Yes.. ideally. Those numbers posted above were still a work in progress, and I was really only concerned about 32+ F degrees, since it will never get to 14F where I am. Tweak till it works for you.
Thanks, and if there are multiple rows, each row down should have slightly higher values than the one above?
Does anyone know where the program stored the factory one so we can compare to that?
Why so many similar tables? Does anyone know what each one is for?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-17-2014, 03:17 PM   #156
mkivsoopra
I'll have to defer to someone more knowledgable to answer those questions.
mkivsoopra is offline   Reply With Quote
Old 12-12-2014, 07:43 PM   #157
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
I've been having lots of cold start issues ever since I started using the E85 OTS maps. It would typically take 5-7 starts every morning to get the car running. Thanks to @Malt and @Terrapin77, I used their values and adjusted the values in the temperature range that's typical for my area (40-65F) this time of the year.
This morning, I was able to start my car on the second crank with a coolant temp of 62F. Gonna keep experimenting to see if I can get it to start on the first.
FWIW, I'm using 100% Propel E85, which measures 78-80% ethanol on my Zeitronix gauge.
Disclaimer.. use at your own risk blah blah blah.
how does your Fuel IPW Compensation A table look like? are they zero'd out? thanks.
zAnSh1n is offline   Reply With Quote
Old 06-10-2015, 10:06 AM   #158
phrosty
Originally Posted by Malt View Post
For those of you that are potentially having cold start issues like me, here is a copy of the tables I've used with success. It starts on the first try 80% of the time and on the 2nd attempt 99% of the time.
@Malt, have you modded your cold start to be less noisy? I found that by backing off on it just slightly, E85 cold starts became significantly more reliable.
phrosty is offline   Reply With Quote
Old 06-10-2015, 08:33 PM   #159
Malt
Drives: 2015 WRX
After an especially cold winter I went back to a 93 tune until summer hit. Never went back to E85 and have since sold the BRZ.
Malt is offline   Reply With Quote
Old 09-13-2016, 12:29 AM   #160
Nah
Drives: 2013 Scion Frs 6mt
....you should share a snapshot of your current base timing b setup.... thanks
Originally Posted by Kodename47 View Post
Well I'd advise only touching one of the timing tables, whether it be base or advance that's up to you. I also like the idea of flat advance tables across each load so you can easily see if there's any timing being pulled, but that's just me.
@troek timing is the only thing that changes with differences in octane as you can run more advance with better fuel. The target AFRs won't change, unless the AFRs appear to be changing as a result.
Nah is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
