Old 12-14-2013, 08:34 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tablet v1.42b maps now available
Hi guys,
Had to few hours free this morning to add more non-USDM ROM support and to tweak the E85 maps. So this update only applies to a few customers overseas and all those running the E85 maps.
v1.42 Changes:
-Added tuned file and developmental XDF (TunerPro) support for ZA1JA01I and ZA1JA010 ROMs (EH 6AT and EU 6AT).
-Removed Beta status for all Stage 2 UEL E85 ROMs.
-Revised Cranking Fuel Injector Pulse Width tables for all E85 ROMs to improved cold weather cold start performance (thanks @mad_sb for suggestion)
Available for download HERE
Have a great weekend!
Cheers,
Shiv
Old 12-14-2013, 09:43 PM   #2
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by shiv@vishnu View Post
Hi guys,
v1.42 Changes:
Cheers,
Shiv
Hey shiv any chance I can those revised tables on my tune?
Installed Mods:
Old 12-14-2013, 09:47 PM   #3
Shiv@Openflash
Drives: 2013 FRS
Done. You have mail
Old 12-14-2013, 09:49 PM   #4
Sojhinn
Sojhinn's Avatar
Just saw. Thanks man! I will be doing some third gear pulls tomorrow morning and then I'll flash the new tune.
Installed Mods:
Old 12-14-2013, 10:28 PM   #5
Malt
Drives: 2015 WRX
Intresting, I had a suspicion that zeroing out the IPW compensation tables and only adjusting the IPW tables might not be the best way to go. I'll flash this right now and give it a try in the morning.
If the IPW adjustments you made Shiv were not sufficient how much would you suggest increasing them by?
Malt is offline   Reply With Quote
Old 12-15-2013, 06:05 AM   #6
Kinaa
Kinaa's Avatar
Drives: BRZ (HKS Superchager)
Hi guys,
v1.42 Changes:
Cheers,
Shiv
Great Job Shiv
I confirm as well that the New ZA1JA010 Rom is working fine I tried both stage 1 and 2 , i will be posting some Data logging later on
Cheers
Kinaa is offline   Reply With Quote
Old 12-15-2013, 06:16 AM   #7
s2d4
s2d4's Avatar
Originally Posted by Kinaa View Post
Great Job Shiv
Cheers
Did you get IAM or KCL working?
Old 12-15-2013, 06:18 AM   #8
Kinaa
Kinaa's Avatar
not sure , but I will post some logs later on
Old 12-15-2013, 06:38 AM   #9
Kinaa
Kinaa's Avatar
one more thing , i can see you have a S/C on your car , as Shiv mentioned before the maps are not dedicated to any type on FI , I tried them out and it did work fine with My S/C , so if you are going to do the same , this will be on your own risk
it might worked for because i didn't have any tune for my ECU and the HKS S/C comes with piggyback F-con computer , but in my case its easy just disconnect the F con and run with the OFT tune.
this might be different for you if your using a different S/C
Cheers
Old 12-15-2013, 06:58 AM   #10
s2d4
s2d4's Avatar
Cheers
Don't know what you are on about, I do not have an SC on my 86, it's bone stock.
Also, not sure what you meant by working when you haven't logged it yet.
Old 12-15-2013, 07:16 AM   #11
Malt
Drives: 2015 WRX
Unfortunately no noticeable improvements on cranking with these maps verses the tweaks I had applied. If anything it got slightly worse as it took 7 attempts to crank this morning. I'll log the crank tomorrow morning and post up logs. Maybe it could be just a matter of further tweaking the ipw tables for just me.
Old 12-15-2013, 07:22 AM   #12
Kinaa
Kinaa's Avatar
Sorry my bad , and if you have a stock 86 you can upload the map to you car and try it your self , in my case I was talking about a specific rom that Shiv added yesterday , which i'm sure no one on the forum tested it before
Old 12-15-2013, 07:50 AM   #13
s2d4
s2d4's Avatar
All good man, checking out a rom with the xdf released yesterday, mine didn't seem to work for those 2 parameters for logging hence my original question.
Old 12-15-2013, 08:29 AM   #14
s2d4
s2d4's Avatar
I may as well ask the questions here for the ZA1JA01I XDF, apologies if this is noobish but I don't now why the following is the way it is. @shiv@vishnu, hope you can shed some light for the beginners.
1. Throttle delta Fuel comp A and B has weird numbers as Y axis.
2. All of the GDI firing angle maps only has one 1 row with 7200 in Y axis, everything else is -0.
3.Close loop AFR A and B has weird numbers as Y axis.
4. Ignition base - has weird numbers as Y axis, it also ends at 7400. Doesn't this need to go to 7600 due to the increase rev limit?
5. Ignition Comp cylinder 1 and 2 - more giberish on Y axis.
6. Fuel Map - ends at 7400 but rev limit at 7600?
7. Ignition advance - ends at 7400 but rev limit at 7600?
8.Idle Targets - more giberish on Y axis although I know this is working as my car idles at around 750 now.
9. ?? DTC table not scaled?? - completely no idea, giberish everywhere.
Don't know if I'll get any clarification but I can't be the only one not getting the above 9 items.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
