Old 04-08-2013, 07:47 PM   #15
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
My FR-S had it's radio installed without the USB plugged in to the back of the head unit. No wonder my phone wouldn't charge... Double check that the monkey who installed your head unit plugged in all the wires.
Narcoden is offline   Reply With Quote
Old 04-08-2013, 07:50 PM   #16
Kayzer Soze
Drives: 2013 BRZ 6MT Satin White Pearl
im trying to figure out why my brz didnt come with a usb port!?
Kayzer Soze is offline   Reply With Quote
Old 04-08-2013, 07:51 PM   #17
Narcoden
Narcoden's Avatar
I think the USB port on a BRZ is in the glove box if I remember correct?
Old 04-08-2013, 07:52 PM   #18
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by SubieNate View Post
Any USB with a data connection charges at a max of .5A as per the USB standards. On a charge only plug you can get close to 1A on most phones. I bought a USB charger for my car so that I can use the GPS on the phone and still charge. Before it would act as if it was charging and then die unexpectedly.
The way Android and Apple signal charge rate is different. Android just shorts the data connection, Apple chargers send a specific voltage that tells the in-phone battery regulator what rate it can charge at. Charging an Android phone on a USB plug meant for Apple products won't hurt it, but it may limit it to .5A. Both will be limited to .5A on a computer or other connection that also has data capability (e.g., our car's plug).
Nathan
I have seen some components (Motherboards) that support the iPhone charging...protocol...for lack of a better term, It will be cool when these standards get...ummm standardized...
It truly is a pain in the A$$ to only barely maintain state of charge on the phone while broadcasting bluetooth audio
Old 04-08-2013, 07:53 PM   #19
SkullWorks
That is correct...In Canadia only though.
Old 04-08-2013, 08:20 PM   #20
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I'm betting the guy didn't plug my USB in. Will test out tonight.
Old 04-08-2013, 09:28 PM   #21
Doughnuts
Doughnuts's Avatar
Drives: 2013 Scion FRS (Whiteout)
I seem to remember the base FR-S radio manual stating that the usb port provides 1.0 amp. As previously mentioned however, the port has a data connection, so it probably wont pull the full amperage available.
Edit: I have heard of people making dedicated charging cables by shorting the data pins in the device side of the cable (leaving the host side disconnected and insulated.) to get around this problem.
Doughnuts is offline   Reply With Quote
Old 04-08-2013, 09:50 PM   #22
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
I have an iPad on a RAM mount. I use a splitter to charge and sync it with the Bespoke. One day I'm sure I'll get around to installing more USB ports.
Sent from my SCH-I605 using Tapatalk 2
PhastekSport is offline   Reply With Quote
Old 04-17-2013, 04:32 PM   #23
EAGLE5
Dismember
EAGLE5's Avatar
It won't recognize USB or my phone. I'm thinking the Scion stereo guy messed up. He managed to scratch the trim while installing. Yes, they replaced them.
Old 04-17-2013, 06:13 PM   #24
DieselxIndustry
Drives: 2013 Firestorm FR-S
Some of you may not be aware of it but there's a second "cigarette lighter port" in the glove compartment for those of you running out of ports to use for your devices.
DieselxIndustry is offline   Reply With Quote
Old 08-11-2014, 08:13 AM   #25
Shedd22
BAMF
Shedd22's Avatar
Drives: 2014 SWP BRZ
Hate to bring up a semi-old thread but I'm having a sort of similar issue. During a recent road trip my phone (Droid RAZR HD) had 1% left on the battery. I plugged it in to the USB port and my car recognized it but it would go from charging to uncharging, to charging to uncharging, and so on.
Since it charges for 1 second at a time I feel like it has the capability to charge properly, but it just doesnt. Has anyone found out any info in regards to why shit doesnt charge? And please no dumbass answers
Shedd22 is offline   Reply With Quote
Old 08-11-2014, 09:12 AM   #26
sklimo
I had similar issues when I was using an expensive USB cable from Best Buy. Picked up a cheap one from RadioShack and no problems since
Shedd22 (08-11-2014)
Old 08-11-2014, 09:23 AM   #27
Shedd22
BAMF
Shedd22's Avatar
Weird. It's worth a try, thanks!!
The Following User Says Thank You to Shedd22 For This Useful Post:
sklimo (08-11-2014)
Old 08-11-2014, 11:40 PM   #28
greencounty
greencounty's Avatar
I've had similar problems with a samsung tablet. I can charge it with the wall plug only when it is off but the same USB cable charges fine in the car with a cigarette lighter adapter.
I was browsing around and found this:
[ame="http://www.amazon.com/Satechi-Converter-Cigarette-BlackBerry-Playbook/dp/B004X71HXU"]Amazon charger[/ame]
It says "Smart-converter is designed to enhance charging compatibility for smartphones which are powered through Micro USB connector and enables quick charge for your device. It may also be used with PC or USB wall charger."
I don't know if I trust it but it sounds like it might fix my problem.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
TPMS reset charge FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-09-2014 01:22 PM
would you turbo or super charge your BRZ/FRS? chenshuo Scion FR-S / Toyota 86 GT86 General Forum 45 03-04-2013 10:13 AM
Does usb port charge ipod? wtout86 Electronics | Audio | NAV | Infotainment 28 12-19-2012 03:05 PM
ECU Charge??? DBacon1052 Issues | Warranty | Recalls / TSB 12 09-18-2012 11:53 PM
Hey guys! Is there ANY way we don't have to pay destination charge? zyzauto BRZ First-Gen (2012+) — General Topics 30 05-07-2012 04:07 PM
