Old 08-22-2012, 10:17 PM   #1
FRiSson
Drives: FR-S MT
TPMS reset charge
I contacted my dealer to get an estimate on a winter wheel swap. They want $26.95 for the swap, which seems okay, and $99 to reset the TPMS, which seems outrageous. Don't they just have to do some simple rfid code change.
So I have a few questions for you guys.
1) What does this service usually cost?
2) Does it have to be performed everytime I change wheels, or can the car computer store two sets set of sensors?
3) Can I buy a device and do it myself?
Thanks in advance
FRiSson is offline   Reply With Quote
Old 08-22-2012, 11:17 PM   #2
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
If it's the same sensors in the same wheel, you don't need to do anything.
If it's new wheels, just don't put sensors into the new wheels (and either live with the light or do the "tape over it" mod)
There are boxes that let you program new sensors, but not out for this model yet. Also there are sensors that "clone" the ids of your existing sensors, so you basically have 2 of each wheel. This is the route I'm going to go once I'm sure they're ready. Again, need to wait for them to make it work with the new sensors.
Khyron686 is offline   Reply With Quote
Old 08-23-2012, 08:57 AM   #3
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
If they're talking about moving sensors from summer wheels to winter wheels then the $99 makes sense.
If you already have sensors in your winter wheels then they're ripping you off. Pairing sensors is a 5 min job.
Old 08-23-2012, 04:16 PM   #4
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
IMHO the best solution is to just leave the sensors out of your winter wheels/snow tires, and ignore the light. Buy an inexpensive floor jack and torque wrench and you can swap your own wheels/tires in less than half an hour and pay nothing for someone else to do it.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-23-2012, 04:26 PM   #5
FRiSson
Drives: FR-S MT
I used to do that, but it took me longer than 30 minutes. I wonder if the insurance is voided with no TPMS?
Old 08-23-2012, 04:34 PM   #6
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
These wheels will fit with these hydrophelic snow tires.
Snow tires retain pliability at lower temprature, but wear fast at ambient tempratures above 65 degrees. The silica in all season tires makes the tread blocks break below freezing.
There are also plenty of reasons to start using your OEM wheels as snow wheels, there is quite an assortment of Winter Tires in the factory 215/45-17 size.
Spartan65 is offline   Reply With Quote
Old 08-23-2012, 04:39 PM   #7
Spartan65
Spartan65's Avatar
Moving sensors is just a matter of changing the valve stem unit, not like it used to be when TMPS first came out they had a SS band that went around the wheel.
Old 08-23-2012, 04:50 PM   #8
neutron256
neutron256's Avatar
Yeah sure, removing it is no big deal, but you have to get the tire off first. I just got a quote to have a set of snow tires mounted on some older wheels I have. It came to just under $100 with balancing.
It sounds to me like they're charging for swapping the sensors to the new wheels (and probably balancing them). Not just for programming them.
Old 08-23-2012, 04:58 PM   #9
Miniata
Don't know why it would be, never heard of any insurance related TPMS issues. Just check your tire pressure regularly. With a cordless impact and lightweight floor jack, it takes me betweeen 5 and 10 minutes to change all four wheels/tires, but I get lots of practice since I do it so often.
Old 08-23-2012, 05:18 PM   #10
Spartan65
Spartan65's Avatar
Is there a Discount Tire Near you, hit them up if there is?
Old 08-23-2012, 07:55 PM   #11
neutron256
neutron256's Avatar
I stick with my local shop. They cost a little more but they service and quility of the work is more important to me then saving $10-20. Plus they usually do free patches and other basic work for their regulars.
Old 08-23-2012, 08:01 PM   #12
FR-S,M.D.
Drives: 2013 Argento Scion FR-S 6AT
What does hydrophelic mean?
FR-S,M.D. is offline   Reply With Quote
Old 08-23-2012, 09:55 PM   #13
serith
serith's Avatar
Drives: 2009 Scion tC RS 5.0
The steelies I throw on my car for my winters wheels don't even have the TPMS installed. I just deal with the indicator light for a few months
09 RS 5.0 -- #862 of 2000 -- 5spd
serith is offline   Reply With Quote
Old 08-23-2012, 11:03 PM   #14
FRiSson
Drives: FR-S MT
They make cordless impact wrenches? Do they have built in torque settings?
That would make things a lot easier!
Bluetooth causing head unit to reset? Eric1855 Electronics | Audio | NAV | Infotainment 4 01-15-2013 08:42 PM
Charge Speed Bottom line VSpec86 AUSTRALIA 38 11-21-2012 05:43 PM
ECU Charge??? DBacon1052 Issues | Warranty | Recalls / TSB 12 09-18-2012 11:53 PM
Charge Speed Bottom line VSpec86 AUSTRALIA 18 08-23-2012 06:54 AM
Hey guys! Is there ANY way we don't have to pay destination charge? zyzauto BRZ First-Gen (2012+) — General Topics 30 05-07-2012 04:07 PM
