Old 08-03-2014, 08:17 PM   #15
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by rice_classic View Post
Had the girlfriend work the pedal...
Is there any reason you couldn't use a vacuum bleeder if you didn't have a helper handy?
Old 08-03-2014, 11:11 PM   #16
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Not sure but I don't see why not if it's effective. I've never used one so I cannot say definitively.
SCCA T4 - FRS
Old 08-03-2014, 11:16 PM   #17
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Aww, no clutch damper to bypass? Shucks!
Old 01-06-2015, 12:59 AM   #18
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
I found a 5/16" wrench actually worked better. The 8mm started to slip. I replaced my line with the MTec line, but as I look, I wish I bought the Chase Bays line. Replaces from the reservoir to the Transmission. The Mtec replaces just the rubber portion. I noticed that my car get's into gear much easier, especially when cold.
I did notice when I was bleeding (really needed some help with that) that I actually had debris in the reservoir. I'm have to replace all the fluid.
G_Rossney is offline   Reply With Quote
The Following User Says Thank You to G_Rossney For This Useful Post:
jcw99 (01-06-2015)
Old 01-06-2015, 08:28 AM   #19
surcy
Vacuum bleeder works perfectly.
surcy is offline   Reply With Quote
The Following User Says Thank You to surcy For This Useful Post:
kiichiro (01-06-2015)
Old 01-29-2015, 11:47 PM   #20
yaguphire
Drives: white-out FR-S
I've never bleed clutch before. Is this similar to bleeding brakes. Clutch in then bleed?
yaguphire is offline   Reply With Quote
Old 02-04-2015, 07:39 PM   #21
yaguphire
Any thoughts anyone?
Old 02-04-2015, 08:06 PM   #22
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
exactly the same. Get a friend to help out. Press clutch, open bleeder valve, close valve, release clutch.
Repeat.
Make sure you don't run out of clutch fluid!
The Following User Says Thank You to continuecrushing For This Useful Post:
yaguphire (02-04-2015)
Old 02-04-2015, 08:17 PM   #23
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
1-man bleeder kits are only $2-$5 at your auto parts stores.
i use mine a lot!
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
The Following 2 Users Say Thank You to azian_advanced For This Useful Post:
chas3wba0 (03-09-2018), Trueweltall (04-29-2017)
Old 02-04-2015, 10:31 PM   #24
yaguphire
Repeat.
Simple enough thanks for chiming in.
Old 03-14-2015, 12:47 AM   #25
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
can anyone make a DIY guide with pictures?
thanks haha
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
akahenry (03-17-2015), Azusa (04-04-2016)
Old 01-02-2017, 07:13 AM   #26
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
Clutch Pedal Stays Down?
Are you supposed to pull the clutch pedal back up after you crack and close the valve?
Or is it supposed to come back up by itself?
BaBaFlyingSheep is offline   Reply With Quote
Old 01-02-2017, 07:48 PM   #27
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
It's supposed to come back up on its own.
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
TelMinz is offline   Reply With Quote
Old 01-02-2017, 09:06 PM   #28
It will not come back by itself unless you have removed the helper spring.
jcw99 (01-03-2017)
Bleeding brakes-cycle ABS system? fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-11-2015 03:57 PM
My Car is bleeding! Ec1990 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-01-2014 11:31 AM
Properly flushing/bleeding radiator fluid? swift996 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-30-2014 03:50 PM
Speed Bleeding time away developer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-31-2012 08:07 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 08:13 AM
