Old 06-09-2014, 12:32 AM   #1
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Another reason to love this car: Clutch Bleeding
Nothing too insightful but I have 35k miles on my car and I noticed that the clutch "felt" different on its stroke. So I thought I would bleed it this weekend.
Here I was expecting to put the car on stands, crawl underneath it etc, when I saw there was no slave, just one MC with the bleeder and its easy to access from under the hood. Had the girlfriend work the pedal and I was all done in 20 minutes with a 8mm wrench, tube with catch can and some off the shelf brake fluid. Just brilliant. I love cars that are easy to work on.
Edit: pedal stroke felt better after the bleed.
Double Edit: I misspoke. The underlined part is incorrect. There is of course a MC and a SC, there would have to be as something would have to be actuating the cylinder bolted to the transmission. The MC is indeed where the reservoir is and the SC is on the tranny. However, usually the MC is larger and the SC is smaller (and hard to get to) but in this case the MC is tiny and the SC is large and it's easy to get to.
PRO86 | WTCC | STL
The Following 8 Users Say Thank You to rice_classic For This Useful Post:
Boofneenee (06-10-2014), F1point4 (06-16-2014), jcw99 (08-03-2014), kiichiro (01-06-2015), MileMonger (02-14-2017), reeves (06-12-2014), Sportsguy83 (06-10-2014), tahdizzle (06-09-2014)
Old 06-09-2014, 12:53 AM   #2
Dezoris
Dezoris's Avatar
You could not ask for a better slave location. Glad it was painless. Now come over and fix my car.
The Following User Says Thank You to Dezoris For This Useful Post:
draggin_az (06-09-2014)
Old 06-09-2014, 01:11 AM   #3
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Upgrade the line when u flush ;-)
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-09-2014, 02:39 PM   #4
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Debating on this, I have 41k but doesn't seem like it needs a bleed. Is there a way to inspect and check if bleed is needed?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 06-09-2014, 04:06 PM   #5
suaveflooder
Would you mind posting pics? Sorry, I've come from mustangs. Clutch was opperated by a steel cable that went from the pedal to the clutch fork.
suaveflooder is offline   Reply With Quote
Old 06-10-2014, 01:08 AM   #6
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
DIY!
ProjectD is offline   Reply With Quote
The Following 3 Users Say Thank You to ProjectD For This Useful Post:
akahenry (06-10-2014), Bg8780 (06-10-2014), suaveflooder (06-10-2014)
Old 06-10-2014, 03:03 AM   #7
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Not unless you like messing with the clutch and checking pressure plate tolerances/distances...
I'm at ~22k miles and can tell it needs a bleed (feels weaker) which I will be doing soon, and when I look at the fluid in the clutch reservoir it's WAY darker than the fluid in the brake reservoir, and they both started off exactly the same. Daily driving you can probably go with 2 years/20'ish k miles between bleeds...but I wouldn't go much past that.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 06-10-2014, 03:26 AM   #8
Vracer111
Vracer111's Avatar
Follow the hydraulic line from the Clutch reservoir to the transmission...literally just a few inches away, right by the intake manifold on the drivers side of the manifold cover. Nipple is ~ 1" away from the banjo bolt connection. Bleed it like you would brakes.
I got picture, see lower RH side of this image I just took (if you look under your hood it will be staring you right in the face...):
The Following 6 Users Say Thank You to Vracer111 For This Useful Post:
Black Tire (06-14-2014), jcw99 (08-03-2014), scionfrs2014 (09-23-2015), suaveflooder (06-10-2014), Tt3Sheppard (06-10-2014), YamahaR86 (01-30-2019)
Old 06-10-2014, 08:57 AM   #9
Tt3Sheppard
It really is right there in front of you. Hah!
I only have ATE Superblue at the moment from bleeding the brakes. Will that be fine for the clutch as well?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 06-10-2014, 10:06 AM   #10
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
yup. same fluid
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
Old 06-10-2014, 12:51 PM   #11
Tt3Sheppard
There is no slave for the clutch?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
Old 06-10-2014, 03:39 PM   #12
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
There's no slave cylinder. Fluid from the master just drips onto the friction material, thus reducing friction. It's actually quite genius.
SloS14 is offline   Reply With Quote
The Following 3 Users Say Thank You to SloS14 For This Useful Post:
ProjectD (06-10-2014), Tt3Sheppard (06-10-2014), Whatabouteggs (01-29-2015)
Old 06-12-2014, 11:12 AM   #13
reeves
My clutch pedal is starting to feel a tiny bit different too.. can't explain it, but it's just not quite as "smooth" as it used to be. Might have to try this soon.
reeves is offline   Reply With Quote
Old 08-03-2014, 06:37 PM   #14
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I couldn't find any threads on this but if I want to replace the cable for a SS one, how do I do this with respect to the fluid and not damaging anything by running the lines dry?
I initially figured I had to drain the fluid in the reservoir, undo the stock cable, catch the some fluid as it spilled out from below the reservoir, screw in the new cable, and then top off the reservoir and do a flush like one would with brakes. But I'm worried I'm going to be running the clutch dry at some point. Or spilling an ass ton of brake fluid.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Bleeding brakes-cycle ABS system? fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-11-2015 02:57 PM
My Car is bleeding! Ec1990 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 04-01-2014 10:31 AM
Properly flushing/bleeding radiator fluid? swift996 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-30-2014 02:50 PM
Speed Bleeding time away developer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-31-2012 07:07 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
