| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Nevermorange FRS
Another reason to love this car: Clutch Bleeding
Nothing too insightful but I have 35k miles on my car and I noticed that the clutch "felt" different on its stroke. So I thought I would bleed it this weekend.
Here I was expecting to put the car on stands, crawl underneath it etc, when I saw there was no slave, just one MC with the bleeder and its easy to access from under the hood. Had the girlfriend work the pedal and I was all done in 20 minutes with a 8mm wrench, tube with catch can and some off the shelf brake fluid. Just brilliant. I love cars that are easy to work on. Edit: pedal stroke felt better after the bleed. Double Edit: I misspoke. The underlined part is incorrect. There is of course a MC and a SC, there would have to be as something would have to be actuating the cylinder bolted to the transmission. The MC is indeed where the reservoir is and the SC is on the tranny. However, usually the MC is larger and the SC is smaller (and hard to get to) but in this case the MC is tiny and the SC is large and it's easy to get to.
PRO86 | WTCC | STL
| The Following 8 Users Say Thank You to rice_classic For This Useful Post: | Boofneenee (06-10-2014), F1point4 (06-16-2014), jcw99 (08-03-2014), kiichiro (01-06-2015), MileMonger (02-14-2017), reeves (06-12-2014), Sportsguy83 (06-10-2014), tahdizzle (06-09-2014) |
#2 |
You could not ask for a better slave location. Glad it was painless. Now come over and fix my car.
| The Following User Says Thank You to Dezoris For This Useful Post: | draggin_az (06-09-2014) |
#3 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Upgrade the line when u flush ;-)
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#4 |
Drives: Whiteout FR-S
Debating on this, I have 41k but doesn't seem like it needs a bleed. Is there a way to inspect and check if bleed is needed?
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#5 |
Would you mind posting pics? Sorry, I've come from mustangs. Clutch was opperated by a steel cable that went from the pedal to the clutch fork.
#6 |
Drives: '04 350Z/ 2013 LR BRZ (LM)
DIY!
| The Following 3 Users Say Thank You to ProjectD For This Useful Post: |
#7 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'm at ~22k miles and can tell it needs a bleed (feels weaker) which I will be doing soon, and when I look at the fluid in the clutch reservoir it's WAY darker than the fluid in the brake reservoir, and they both started off exactly the same. Daily driving you can probably go with 2 years/20'ish k miles between bleeds...but I wouldn't go much past that.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#8 | |
I got picture, see lower RH side of this image I just took (if you look under your hood it will be staring you right in the face...):
| The Following 6 Users Say Thank You to Vracer111 For This Useful Post: | Black Tire (06-14-2014), jcw99 (08-03-2014), scionfrs2014 (09-23-2015), suaveflooder (06-10-2014), Tt3Sheppard (06-10-2014), YamahaR86 (01-30-2019) |
#9 | |
I only have ATE Superblue at the moment from bleeding the brakes. Will that be fine for the clutch as well?
2013 Ford Focus St
#10 |
StreetKart
Drives: 2014 Scion FR-S Monogram
yup. same fluid
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
| The Following User Says Thank You to Roadcone For This Useful Post: | suaveflooder (06-10-2014) |
#11 | |
2013 Ford Focus St
#12 |
Drives: 2013 FR-S whiteout
| The Following 3 Users Say Thank You to SloS14 For This Useful Post: |
#13 |
My clutch pedal is starting to feel a tiny bit different too.. can't explain it, but it's just not quite as "smooth" as it used to be. Might have to try this soon.
#14 |
When In Doubt...
Drives: Slowww
I couldn't find any threads on this but if I want to replace the cable for a SS one, how do I do this with respect to the fluid and not damaging anything by running the lines dry?
I initially figured I had to drain the fluid in the reservoir, undo the stock cable, catch the some fluid as it spilled out from below the reservoir, screw in the new cable, and then top off the reservoir and do a flush like one would with brakes. But I'm worried I'm going to be running the clutch dry at some point. Or spilling an ass ton of brake fluid.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
| Bleeding brakes-cycle ABS system? | fasteddy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 07-11-2015 02:57 PM |
| My Car is bleeding! | Ec1990 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 04-01-2014 10:31 AM |
| Properly flushing/bleeding radiator fluid? | swift996 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 01-30-2014 02:50 PM |
| Speed Bleeding time away | developer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-31-2012 07:07 PM |
| Brake bleeding order? | ubersoph | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-10-2012 07:13 AM |
