Bleeding brakes-cycle ABS system?
Does anyone know what would be required to cycle the ABS when bleeding in new fluid. I suspect I can take it to the dealer and have them do it. I could also do as I have in the past and bleed, go out and drive engaging the ABS and bleed again. Though that may not be 100% effective.
I am changing up to Castrol SRF and want to get a full fresh bleed before going to the track. I am considering having a mechanic I know do it, but he is not sure if the software he uses will give him access to the ABS pump. Just looking for ideas here. Thanks. Pat |
| The Following User Says Thank You to fasteddy For This Useful Post: | Createddeleted (07-11-2015) |
I was able to fully flush mine without anything special. I can say for 100% sure all the fluid was flushed because I switched to ATE Super Blue so it's obvious when the OEM fluid is flushed out.
Drives: BRZ Premium Black
I just got the Techstream software and cable. I am able to activate ABS soleinoids, but it does not sound the same way it does as when it activates on the road.
Anybody have any experience cycling the ABS/EBC system using techstream for the purpose of more thorough brake bleed? |
| The Following User Says Thank You to AlexTheGreek For This Useful Post: | Createddeleted (07-11-2015) |
| Anyone adding 2 cycle oil with TCW3 to their gas?? | BRZnut | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 137 | 06-18-2019 06:13 AM |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
| Toyota confirmed to be exploring forced induction for GT86 mid-cycle refresh | AZOOZ_95 | Scion FR-S / Toyota 86 GT86 General Forum | 79 | 03-12-2013 10:40 PM |
| Speed Bleeding time away | developer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-31-2012 07:07 PM |
| Brake bleeding order? | ubersoph | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-10-2012 07:13 AM |
