Old 01-30-2014, 09:10 AM   #1
swift996
swift996's Avatar
Properly flushing/bleeding radiator fluid?
Sorry for the basic question but I saw somewhere that you should bleed the coolant system via a bleed screw by the firewall.
I plan to replace my radiator tomorrow night with an aftermarket one and was wondering if anyone could help me understand the procedure for filling and ensuring proper system performance?
I found this DIY:
http://www.hps-siliconehoses.com/wp/...llation-guide/
Would I fill via the fill and use loosen the bleeder screw until fluid drips out? Is this with the car off or on? Sorry for the basic question. In the past, I've just filled and went on in life.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-30-2014, 09:38 AM   #2
Mikem53
Drives: FR-S 6MT
I found this DIY:
Yes.. Open bleeder screw, fill.. Fluid should push the air out, when you see fluid, close and drive.. Most systems will push air out through the expansion tank tube, this is just a way to bleed the system quicker. Being flat and weird has its quirks..
Mikem53 is offline   Reply With Quote
Old 01-30-2014, 02:50 PM   #3
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Yeah when doing my install we didn't use the screw..... It takes a good amount longer for the air bubbles to get out.
SubaSteve is offline   Reply With Quote
Bleeding brakes-cycle ABS system? fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-11-2015 02:57 PM
anyone going to the flushing meadows meet tonight sid3way5 NY / NJ / CT / PA 0 11-15-2013 09:49 AM
Always secure your GoPro cam properly :-( Killerbee FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 08-16-2013 02:42 AM
Speed Bleeding time away developer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-31-2012 07:07 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
