Old 08-01-2014, 05:14 PM   #15
nunonuna
nunonuna's Avatar
Originally Posted by Shiv@Openflash View Post
Nice! Do you know what a stock FRS puts down on that Dyno Dynamics dyno?
I think Dynosty's dyno dynamic read 153.7 whp base fr-s.
nunonuna is offline   Reply With Quote
Old 08-02-2014, 12:05 AM   #16
KonTheory
Drives: '14 FRS
If thats the case I feel much better about 179.7
I was really hoping to crack the 180... but the guys there said it would have been a little higher if it wasnt so hot out..
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
Old 08-03-2014, 01:48 AM   #17
nunonuna
nunonuna's Avatar
I will also try to dyno mine next Saturday which is gonna be same dyno, but I dont know what number its gonna show because the shop im visiting always shows lower reading than what other people get from other dyno shop with same dyno. will see how mine comes out.
Old 08-03-2014, 05:08 PM   #18
mid_life_crisis
Drives: FR-S 10 #103 AT
So I finally started looking at the tables. Can someone who understands tuning explain what has to be done to increase the rev limit? There is obviously a rev limit setting, and you need to add additional lines to other tables. Which tables need to be extended? I found that the ignition tables get altered so the highest rpm is listed as the target, but why is the timing changed to be a negative value? As rpm increase, shouldn't the timing continue to advance, or at least stay stable?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-03-2014, 06:26 PM   #19
steve99
Drives: FT86
The timing reduction is part of the soft rev limit as is the reduction in delta from 350 to 50 rpm in the rpm limit/fuel cut tables
The Following 2 Users Say Thank You to steve99 For This Useful Post:
mid_life_crisis (12-12-2014), RD1428 (01-01-2015)
Old 08-03-2014, 08:25 PM   #20
JB86'd
JB86'd's Avatar
Drives: JAWS
@steve99 @Shiv@Openflash reducing the rev limit back to 7500 wouldn't require making any other changes correct? and disabling LC and FFS simply requires setting all associated tables to 0 right?
JB86'd is offline   Reply With Quote
Old 08-03-2014, 09:30 PM   #21
steve99
Drives: FT86
for the LC & FFS yes just set the delta=0 for both
The rev limit will require some changes to a couple of tables to get it to work correctly
Base timing B will need the RPM axis changing from 7600 to 7500 and next one from 7450 to 7350
Then the Rev Limit Fuel Cut values from 7600 to 7500 and 7550 to 7450
ie take 100rpm off those 4 values. should do it.
JB86'd (08-03-2014)
Old 08-03-2014, 09:47 PM   #22
JB86'd
JB86'd's Avatar
Drives: JAWS
Thanks a ton! @Shiv@Openflash can you confirm this is all that's needed to lower the rev limit safely?
Old 08-03-2014, 10:18 PM   #23
JB86'd
JB86'd's Avatar
Drives: JAWS
So it looks like Base Timing A is set at 7400..should I lower it to 7350 or 7300? Lowered Base Timing B to 7500.
Old 08-03-2014, 10:22 PM   #24
steve99
Drives: FT86
Attachment 87037
no need to touch the BASE TIMING A it only used for limp home mode I believe :-)
Old 08-03-2014, 11:21 PM   #25
JB86'd
JB86'd's Avatar
Drives: JAWS
Totally misunderstood you @steve99 I think I've got it now! Thanks for your knowledge and help
Old 08-03-2014, 11:47 PM   #26
steve99
Drives: FT86
Attachment 87044
No worries mate, looks sorted now
Old 10-23-2014, 11:54 AM   #27
mid_life_crisis
It can certainly be implemented just by copying the ignition A and ignition B tables (and rev limit values) over from the 6MT map. But to be honest, I don't usually do things like that on Auto cars. Sometimes applying soft rev limits can have an impact on shifting performance when in automatic mode.
I tried implementing the soft rev limit and it works beautifully. I haven't noticed any difference in shifting when the car is left in automatic mode after several days of driving.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
YEAHdams (01-01-2015)
Old 10-23-2014, 01:50 PM   #28
phrosty
I also use the soft rev limit. I did notice a couple times if I'm up around 7600, it seems to take about twice as long to shift as normal. Our power band peaks before that in NA so not really a big deal, but with FI it might present an issue.
phrosty is offline   Reply With Quote
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
Raise or stay? Bongertz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-16-2014 04:12 AM
Raise or stay? Bongertz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-03-2014 12:57 AM
Raise Suspension for Winter? Foobar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-25-2012 03:20 PM
Raise BRZ djenriquez07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-14-2012 01:28 PM
