Drives: 2015 Raven FR-S 6MT
Does OFT raise rev limiter?
I'd like to be able to hit 60 instead of 58 in 2nd gear. Does OFT make this possible? Anyone run a good 0-60 in just 1st and 2nd gears with with a rev limiter raised due to a tune?
Turning is for Nerds
Drives: 35 characters is not enough
Definitely possible, I know a few autocross guys who are running 7800 or 7900 for just that reason. Not sure if OFT has rev limit per gear though.
Drives: 2013 FRS
We do raise the rev limit to 7600rpm in all our OTS maps (for 6MT cars). To be honest, I'm not sure what MPH it translates to in 2nd gear but I'm pretty sure it's over 60.
Drives: 2014 Pearl BRZ Limited
Tire diameter (in.): 24.62
RPM: 7600 1st Gear Ratio: 3.626 2nd Gear Ratio: 2.188 3rd Gear Ratio: 1.541 4th Gear Ratio: 1.213 5th Gear Ratio: 1.000 6th Gear Ratio: 0.767 Final Drive Ratio: 4.100 1st Gear (mph): 37 2nd Gear (mph): 62 3rd Gear (mph): 88 4th Gear (mph): 112 5th Gear (mph): 136 6th Gear (mph): 170
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
That's awesome. So I'm assuming that allows for around a 6 second time? Getting closer to buying this thing...
The OFT is WELL 'worth it's weight in gold'. Best purchase I have ever made for a vehicle as far as power/cost goes. Not only does it unleash quite a bit of hidden power, it immensely smooths out the overall feel of the engine, not to mention being able to run e85. Also, you have full data monitoring/logging capabilities, and being able to input that info into VirtualDyno in kinda kool. I was on the fence for a while, but I am so glad I sprung for it.
#7 | |
Drives: FR-S 10 #103 AT
Another question that I've asked elsewhere and not had answered, on the subject of rev limits, is: why did the automatics not get the new soft rev limit setup? We can and frequently do drive in full manual mode.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
Drives: '14 FRS
I dunno if this helps your decision..
but I had my car dyno'd with the 1.59 map All I have is a nameless axleback and a drop in air filter
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
#9 | |
Drives: 2013 FRS
Cheers shiv |
#10 |
Drives: 2013 FRS
#11 | |
Drives: '14 FRS
But I was hoping for exactly what I got so I was very pleased with this
#12 | |
Off Topic
#13 | |
And this still doesn't explain why the 6AT didn't get the soft rev limiter like the 6MT did.
#14 | |
Drives: 2013 FRS
| Coilover to Raise Ride Height | Furtive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 48 | 07-28-2014 12:57 PM |
| Raise or stay? | Bongertz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 07-16-2014 04:12 AM |
| Raise or stay? | Bongertz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-03-2014 12:57 AM |
| Raise Suspension for Winter? | Foobar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 10-25-2012 03:20 PM |
| Raise BRZ | djenriquez07 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 08-14-2012 01:28 PM |
