Old 04-23-2014, 01:08 PM   #673
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
C38 kit being installed locally on an automatic.
KraftWerks is offline   Reply With Quote
The Following 2 Users Say Thank You to KraftWerks For This Useful Post:
illmatic (04-23-2014), JonAvalon (04-23-2014)
Old 04-23-2014, 05:51 PM   #674
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
That thing looks beefy!
digital_assassin is offline   Reply With Quote
Old 04-25-2014, 05:50 AM   #675
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Has anyone found a thermostatically controlled oil cooler kit yet that will work with the KW kit?
Old 04-25-2014, 05:46 PM   #676
KraftWerks
KraftWerks's Avatar
Here are some third party results we're not sure everyone has seen, this is with the standard C30-94 Kraftwerks Kit:
http://www.onpointdyno.com/?p=3366
"Richard’s 295whp Kraftwerks Supercharged FRS"
The first time I got my hands on a Rotrex was when Modified editor, David Pratte brought me a Kraftwerks kit to install in his Civic racecar. I couldn’t believe my eyes when the car made 400whp with that kit. Kraftwerks has done it again with their FR-S kit. From what I saw the materials used in the kit are top level, with beautifully machined and anodized pieces.
Because these ECUTek kits have locked tunes, we always recommend clients purchase the “tuner” kit, so that they don’t spend needless money on a tune file we will have to overwrite. It turns out that was the right decision for Richard, as he ended up spending a small amount more than the “tuned” kit would have cost from Kraftwerks, but received custom dyno tuning time specific to his car, his modifications and Canadian fuel and climage. Now as he makes more changes, we have the base map and can continue to work on that tune.
The car made great power, and drives wonderfully on the street. The transition from cruise to full throttle is seamless and the car has the perfect amount of power, with factory like response. This is how Toyota should have sold the car!
The Following User Says Thank You to KraftWerks For This Useful Post:
mit_peid (04-25-2014)
Old 04-25-2014, 05:59 PM   #677
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I'd love to see third party results of the C38 :-)
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
Calum (04-25-2014)
Old 04-25-2014, 07:36 PM   #678
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
According to the comments in the onpointdyno link, dyno was done on 94 octane Canadian gas. IIRC, Bill @Delicious has stated that each octane accounts for about ~8hp. From a peak of 295hp minus 24hp going from 94 octane to 91 octane you get ~271 hp. Still kind of on the high end I believe since most dynos I've seen for this kit seem to suggest headers/exhaust don't really do much. Wondering if this is on the low boost or high boost pulley...
mit_peid is offline   Reply With Quote
Old 04-25-2014, 08:29 PM   #679
KraftWerks
KraftWerks's Avatar
We're working on an automatic FR-S right now! We're still in the process of tuning, here are some early results! Some of you might like these numbers, don't forget we have the group-buy going right now also
-Baselined with 91 Octane, automatic with header, overpipe and exhaust.
-Kraftwerks kit has a C38 tuned on E85
JonAvalon (04-28-2014), mit_peid (04-25-2014)
Old 04-25-2014, 09:10 PM   #680
Staf00
Drives: SWP DZE
Just wanted to ask...what led you guys to choose the C38-81 in particular, instead of say the C38-71 or C38-91/92? How much air is flowing w/ the high boost and low boost respectively, if you don't mind me asking.
Staf00 is offline   Reply With Quote
Old 04-25-2014, 09:53 PM   #681
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Had the pleasure of dealing with Joe D and Brandon over at KW customer service today. I'd been putting off requesting my cogged idler pullies and even though I didn't have the normally requested information to reference, they were able to get me taken care of promptly and efficiently. Props to them, if you guys had a review section on your site I'd leave you 5 stars, but you don't so I'll leave this here. Thanks again KW.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Zach3794 is offline   Reply With Quote
The Following User Says Thank You to Zach3794 For This Useful Post:
KraftWerks (04-28-2014)
Old 04-28-2014, 01:27 PM   #682
KraftWerks
KraftWerks's Avatar
Our decision was made in testing, and comparative end cost for the end user, this was the best result.
Old 04-28-2014, 01:34 PM   #683
KraftWerks
KraftWerks's Avatar
Thanks for the kind words @Zach3794!
Old 04-28-2014, 02:20 PM   #684
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I've also requested the cogged pulleys and spoken with Joe. Thanks guys
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Old 04-28-2014, 03:37 PM   #685
KraftWerks
KraftWerks's Avatar
Another update from ONPOINT using the standard C30-94 Kraftwerks System:
"Here are the final numbers with the KraftWerks Performance Group supercharged FRS installed by Teknotik. Made 330whp with the Meth. Detuned to 300whp with the meth to protect against a meth system failure. Tuned with EcuTek International Ltd as always using their hybrid speed density and custom map switching via the cruise control stock to toggle between 330 and 300whp meth maps, and a safe gasoline map."
zoth (04-28-2014)
Old 05-12-2014, 12:56 PM   #686
rickspecd
rickspecd's Avatar
Drives: 2013 Scion FRS
Check out our Scion FRS with Kraftwerks Kit.
[ame="https://www.youtube.com/watch?v=3U-GfSjYGmU&list=UU9jNud6sBy8P5fePlwEo1-Q"]DPS Kraftwerks Powered Scion FRS Shop Car on DynoJet - YouTube[/ame]
rickspecd is offline   Reply With Quote
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 08:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 06:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 08:01 PM
