Old 04-17-2014, 02:55 PM   #43
reeves
Originally Posted by OICU812 View Post
I know what you're saying but honestly I looked at this from every angle on our car and where it sits and I think the odds are VERY high for it to get damaged in any way. We"re talking a height reach difference of a quarter inch at best.
Yea if you run across a situation where you're putting the Fumoto valve at risk of being broken off or damaged, then you've got way bigger problems than oil leaking from your car. Trust me, I drive my car off-road all the time (involuntarily, of course) and I've hit some pretty rough terrain... My Fumoto was the last thing at risk of getting damaged.
Old 04-17-2014, 06:43 PM   #44
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
Originally Posted by suaveflooder View Post
You sir, have inspired me to try out the quik valve. I have about 3k more miles until the next oil change but will install then! I can't wait!
ive know about the valve for a while but i just ordered mine today because the first oil change that isnt free is coming up. i went with the no nip drain and also added the 1 dollar clip. my car isnt going to be lowered so im not stressing the risks all that much
mrlewistan is offline   Reply With Quote
Old 04-17-2014, 06:47 PM   #45
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
was your fumoto okay?
Old 04-17-2014, 06:56 PM   #46
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by bdbx18 View Post
Yeah I used to do the topside dipstick method with my Bimmers which I'm told it is SOP. So when I had a longer commute and got a Civic Hybrid, I carried it over to that car which now has a roughly 5 inch piece of tubing left in the oil pan. Some cars have a kink or an edge or something that would make it a bit difficult to pull the entire tube straight out. Much gentle cajoling and massaging transitioned to full out anger after about an hour thereby a full power yank which left a piece lodged in there. Dipstick still works so it must have fallen into the pan.
Removing the dipstick tube on the FRS/BRZ takes 10 seconds, then you can insert a much larger diameter tube than you can with trying to snake down the dipstick tube.
The added benefit is that you know you are at the bottom of the oil pan with your tube (hopefully grabbing any heavy debris in the process, if there is any) and you can also extract the oil a LOT faster due to the larger tube
My e36 never saw the drain bolt removed lol
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-18-2014, 02:02 AM   #47
suaveflooder
Ordered mine today as well. It'll still be a bit before I get to put it on, but I went with the short nipple one and also ordered the clip.
suaveflooder is offline   Reply With Quote
Old 04-18-2014, 02:45 AM   #48
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I honestly wouldn't even bother with the clip, just one more step involved in changing your oil.
Once you get the valve in your hands you'll realize it won't easily spring into the "open" position.
The Following User Says Thank You to Andrew025 For This Useful Post:
suaveflooder (04-18-2014)
Old 04-18-2014, 02:48 AM   #49
suaveflooder
Good to know! I figured it was only a dollar…might as well buy just in case.
The Following 2 Users Say Thank You to suaveflooder For This Useful Post:
mrlewistan (04-18-2014), OICU812 (04-18-2014)
Old 04-18-2014, 03:00 AM   #50
reeves
Not one scratch or dent on it.
The Following User Says Thank You to reeves For This Useful Post:
Old 04-18-2014, 10:19 AM   #51
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
those saying using an oil drain pump thru the dipstick is bad have obviously never owned a boat before.
86-tundra is offline   Reply With Quote
Old 04-18-2014, 10:27 AM   #52
Mikem53
Drives: FR-S 6MT
That's because of access to the sump on a boat is usually difficult. It's still better to drain the sump from its lowest point..
Mikem53 is offline   Reply With Quote
easiest color to keep looking clean? fatoni Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 10-10-2013 07:21 PM
Easiest way to get to the over-pipe? Doing an install... seven Engine, Exhaust, Transmission 7 02-03-2013 07:38 AM
Colors easiest to keep clean yet looks good fitcious Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2013 02:22 PM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
