Old 04-16-2014, 08:21 PM   #15
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
or you can just buy an aftermarket magnetic drain plug.....
Panda Mao is offline   Reply With Quote
Old 04-16-2014, 08:23 PM   #16
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Takes me about 7 minutes total. And i don't use that Fumoto crap.
Ironically enough, it takes me more time to put the oil back in the bottle to get it recycled.
Old 04-16-2014, 08:32 PM   #17
wheelhaus
wheelhaus's Avatar
+1 for the Fumoto "crap".
So easy and so clean. Only need to raise the front of the car high enough to reach my arm under there. No tools, lifts, or jack stands necessary.
Old 04-16-2014, 08:49 PM   #18
dem00n
dem00n's Avatar
Drives: Scion FRS
Or just another thing to fail.
Don't play with parts that don't need to be changed, you'll learn.
Also, why would you raise your car without jack stands?
Old 04-16-2014, 09:10 PM   #19
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
My problem after purchasing a fumoto valve with a lowered car is that my car is to low for a hydraulic jack.... i have to drive up on a spare piece of 1/2" mdf for that extra clearance. easy my ass
supramkivtt2jz is offline   Reply With Quote
Old 04-16-2014, 09:12 PM   #20
dem00n
dem00n's Avatar
Drives: Scion FRS
Fumoto valve is great if the oil plug isn't overly exposed, which is it in the twins. I've seen them on other cars, they're very easy to use. But on this car? Sure, we've no failures.
Old 04-16-2014, 09:17 PM   #21
wheelhaus
wheelhaus's Avatar
Fumotos are extremely reliable, they're just an easy target for paranoia. Another benefit is that they are installed once and can be left in place. I've seen far more problems with standard bolts being cross threaded, leaking, overtorqued, broken, forgotten, etc.
There's no need for jack stands because only my arm/shoulder are under the car for the 5 seconds it takes to slide a shallow oil container into place and flip the valve's lever. I can't remember, but I don't believe the tires even leave the ground.
Old 04-16-2014, 09:18 PM   #22
wheelhaus
wheelhaus's Avatar
How is it overly exposed? It doesn't stick below the metal belly pan.
Old 04-16-2014, 10:52 PM   #23
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Had them on more vehicles then can recall they're 100% fine and make for less mess. I don't see any issue with them on this car and they're well tucked under and away from hurting anything.
Old 04-16-2014, 11:11 PM   #24
dem00n
dem00n's Avatar
Drives: Scion FRS
I can't seem to recall the exact model, but there was a Nissan that was having disintegrating fuel injector seals. This was early in the fuel injection days, Nissan engineering department assured everyone that these seals wouldn't fail because the area was deemed safe and that so many other cars already had them. Sure enough, there was a recall on the seals.
300ZX maybe? No, i think those were fuel line clips. Something in that era.
The point of my horrible story is, you can have any object which works for many applications, but it might cause a castorphic faileure in one that doesn't seem to fit just right. If the oil plug was perhaps in an area that wasn't as exposed as this one, i'd consider it.
To me, this is safe. Sorta, i'd have to see what car this is, etc. Just a random pic.
Our cars our low, i take many things into considerations. Water, random objects in highways, branches, etc.
This doesn't seem safe to me.
It sticks out a lot, a branch at the wrong location and time could easily open that up or even break it off, metal debris?
Oil pans aren't tough, it seems every girl i've dated has learn that the hard way. I keed i keed.
The Following 2 Users Say Thank You to dem00n For This Useful Post:
86-tundra (04-18-2014), Jertronic (07-20-2014)
Old 04-16-2014, 11:25 PM   #25
OICU812
Just a dude
OICU812's Avatar
I've got the short nipple version. By time it got hit and ripped off I'd have much larger problems like my whole pan and half the under guts being well...gone. Lol.
I know what you're saying but honestly I looked at this from every angle on our car and where it sits and I think the odds are VERY high for it to get damaged in any way. We"re talking a height reach difference of a quarter inch at best.
Old 04-17-2014, 12:25 AM   #26
M3_Dust
so it's the fault of the oil drain plug that you lowered your car and now you can't fit a jack under it? am I really going to have to deal with these types of posts on this forum? bud, get yourself some ramps or an ultra-low lift point floor jack, the right tools make any job easier.
definitely
M3_Dust is offline   Reply With Quote
Old 04-17-2014, 12:37 AM   #27
wheelhaus
wheelhaus's Avatar
This one might work. It's really low and has a loooong reach. I f anyone would like, I can set mine up (stock ride height, no front lip) and measure clearance for a baseline to compare.
Old 04-17-2014, 12:53 AM   #28
SOLDIER [X]
Drives: 2014 SWP BRZ Limited
all of the contaminants and sediment wind up on the bottom of the oil pan so you are continuously putting that stuff through your engine if you just suck the fluid out the top vs. draining out of the bottom of the pan. sure it's easier but you're not doing your engine any favors
Doesn't the dip stick measure the oil level from the pan? Isn't he pulling directly from the pan in this manner or am I just understanding this wrong?
SOLDIER [X] is offline   Reply With Quote
easiest color to keep looking clean? fatoni Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 10-10-2013 07:21 PM
Easiest way to get to the over-pipe? Doing an install... seven Engine, Exhaust, Transmission 7 02-03-2013 07:38 AM
Colors easiest to keep clean yet looks good fitcious Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2013 02:22 PM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
