Old 03-25-2012, 09:09 PM   #29
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I think its the other way around, the higher the temperature, the less blind you will put on the incoming drivers.
Old 03-25-2012, 09:09 PM   #30
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
Something like that.
so, by your logic, people who run 4300k/3100lm [oem] or 6000k/2900lm HIDs are jackasses on the road??? since they are brighter than 8000k/2500lm...
zAnSh1n is offline   Reply With Quote
Old 03-25-2012, 09:11 PM   #31
OrbitalEllipses
Drives: Attitude
Originally Posted by zAnSh1n View Post
so by your logic, people who run 4300k/3100lm [oem] or 6000k/2900lm HIDs are jackasses on the road??? since they are brighter than 8000k/2500lm...
Nope. 4300K is the proper temperature. The jackass in his black Acura Integra with purple lights is not at the proper temperature though.
Old 03-25-2012, 09:15 PM   #32
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
purple? haha, what is that, like 12000k?
i think you're assuming that the 8000k is solid blue or something, but it's mostly white with a little bit of blue hue... and i see what you're saying, that's why i think anything above 8000k should be left to those drivers you've mentioned...
Old 03-25-2012, 09:31 PM   #33
Sportsguy83
Drives: Limited BRZ
You have the concept wrong. It's not about a "proper" color. The only thing that can blind the other cars is the highest output possible and then the hadlights pointing in the wrong direction. Having a higher temperature light that produces less brightness has nothing to do with blinding lights. The less brightness, the less blindness
And really there is no "proper" color, there are just standard colors and different colors.
Old 03-25-2012, 09:41 PM   #34
MRZ415
Drives: 2015 Subaru WRX
Well at least even at higher temps its still brighter
than most halogens... my osram rally h7 outputs 2100 lumies
but my color temp is yellowish white.
MRZ415 is offline   Reply With Quote
Old 03-25-2012, 09:54 PM   #35
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
^^^ what they said :]
Old 03-25-2012, 09:57 PM   #36
OrbitalEllipses
Drives: Attitude
There's a perception of proper color, because past a certain color temperature the LUMEN output is BELOW what the standard halogen is. That's my understanding and I don't care what you say.
Old 03-25-2012, 10:00 PM   #37
Longhorn248
Hook 'em
Longhorn248's Avatar
The bold portion is correct, as for the rest of the argument you guys are having, carry on
Longhorn248 is offline   Reply With Quote
Old 03-25-2012, 10:12 PM   #38
Sportsguy83
Drives: Limited BRZ
Which proves my point further, the higher temp, the lower Lumen output so the less the lights will blind other drivers. "Perception" is very subjective your perception is not the world's perception. I get it you don't like it. You don't have to like it. But don't say it bothers more the oncoming driver becasue it doesn't you just said it. Lower Lumens.
Old 03-25-2012, 10:15 PM   #39
DRACHENV6
Drives: tata nano
4300k on a proper setup will still get you that blue flicker at the cutoff line. I think the reason why people do 6k+ hid is to achieve that same color effect without projectors. 4300k S2000 headlights look blue when you see them head on unlike those ghetto aftermarket kits because they also have a proper projector.
8000k blue hids with sacrificed visibility + 3000k yellow fogs (glare)?
no thank you
You guys may or may not be aware but the bluer the light, the worse your night vision becomes. Google bleaching of the receptors in your eye (rods and cones).
DRACHENV6 is offline   Reply With Quote
Old 03-25-2012, 10:24 PM   #40
Sportsguy83
Drives: Limited BRZ
^^ I agree with you completely. I will not sacrifice pretty for safety. I will keep the 4300K and I will be ok with them. I just like the blueish color but like I said, I have not owned a car with HID's so most probably I will be extremely happy with the 4300K
Old 03-25-2012, 10:27 PM   #41
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i am well aware of all these drawbacks, "anything other than 4300k = bad," but the difference is very minimal, it really just comes down to the "look"... of course i am not talking about the purple/pink beams [those are the extremes]... i mean, after all, these aren't professional-grade applications or anything...
Old 03-25-2012, 10:31 PM   #42
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
statements like this sounds a bit like an overstatement...
yes, it's less output on paper, but would you really notice the difference? i doubt it, especially for standard applications... whether you decide to go with 6000k/8000k instead, it's still nearly 3x brighter than conventional halogens...
