Old 03-25-2012, 02:25 AM   #1
MRZ415
Drives: 2015 Subaru WRX
Question BRZ D4S bulb ?
Checking the BRZ manual I was able to determine that
the HID use D4S bulb ... is that good ?
I know of D1S D2S D3S D4S ?
does the higher number D4S mean its the BEST of the lot ???
I am a noob and never own a car with HID before ...
and I did google HID headlights and check around a bit...
I know
D=Discharge...
4= # ofDesignatior.. and
S=standard so it use plain glass shield or something ...
MRZ415 is offline   Reply With Quote
Old 03-25-2012, 03:04 AM   #2
gdi2290
Web Designer/Programmer
gdi2290's Avatar
Drives: WRB BRZ Limited (Lemon)
I wouldn't say the best just a different type, but then again I never had HIDs lol
gdi2290 is offline   Reply With Quote
Old 03-25-2012, 03:04 AM   #3
Dark
Elite Padawan
Dark's Avatar
What do you mean by good? It is a bit cheaper than HID in 3 series.
Dark
Dark is offline   Reply With Quote
Old 03-25-2012, 03:31 AM   #4
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
just a different design, same draw/output...
there are many more different types of halogen bulbs, but you wouldn't say one socket type is superior than the other, especially just by the number designation [ie- 9005 < 9006], would you?
zAnSh1n is offline   Reply With Quote
Old 03-25-2012, 09:17 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Actually less draw and less output. D4s is eco xenon. Output is ~100 lumens less than d2s. D4s runs at 42v instead of the 85v for d2s. D4s is also mercury free.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2012, 10:10 AM   #6
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
D1S = Mercury 85V Bulb w/Built-in Igniter, Plain Glass for Projector
D1R = Mercury 85V Bulb w/Built-in Igniter, Shielded Glass for Reflector
D2S = Mercury 85V Bulb w/o Built-in Igniter, Plain Glass for Projector
D2R = Mercury 85V Bulb w/o Built-in Igniter, Shielded Glass for Reflector
D3S = Mercury-Free 42V Bulb w/Built-in Igniter, Plain Glass for Projector
D3R = Mercury-Free 42V Bulb w/Built-in Igniter, Shielded Glass for Reflector
D4S = Mercury-Free 42V Bulb w/o Built-in Igniter, Plain Glass for Projector
D4R = Mercury-Free 42V Bulb w/o Built-in Igniter, Shielded Glass for Reflector
Up until about 2011 (starting in around 2004), D4 bulbs were only used by Toyota/Lexus, Honda started using the D4S in the CR-Z. They're not bad bulbs, and I think they will become more common, but right now they are currently almost exclusively used by Toyota.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 03-25-2012, 10:26 AM   #7
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
Jeff,
Fantastic attribute round up on common HID bulbs! I am going to copy it for future reference.
Lighting Red is offline   Reply With Quote
Old 03-25-2012, 10:45 AM   #8
Brzer
Drives: BRZ, 2011 Outback 3.6R
Actually from my research the only downside with the D4S bulb that I can see is a shorter bulb life. The beamspread actually looks better and the lumen output is the same as the D2S, at least according to the info on this post.
http://www.hidplanet.com/forums/show...-yours!!/page4
Brzer is offline   Reply With Quote
Old 03-25-2012, 10:52 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Three questions
1) Does anyone know what color temperature are the OEM bulbs ?
2) For those on the know, what is your favorite color temperature for HID headlights?
3) Preferred brand
Old 03-25-2012, 11:05 AM   #10
MRZ415
4300k ? most light on the road ? 5000K is WHITE light... slightly less output...
6000K is diamond white.. blue white slightly less output.
Old 03-25-2012, 11:16 AM   #11
Jeff Lange
Jeff Lange's Avatar
OEM is 4300K, it has the most light output, and is my preferred colour. 5000K isn't terrible either, but anything above that I do not care for, but that's a personal thing as far as colour is concerned. 4300K has the most light though.
There are some decent brands out there, but D4S is a bit harder to find bulbs for. Philips are very good and used to be OEM for Toyota/Lexus, they have since switched to a Japanese supplier Toshiba-Harison, which are very good as well. I am running the OE Toshiba-Harison bulbs in my IS.
Jeff
Old 03-25-2012, 11:23 AM   #12
Sportsguy83
Drives: Limited BRZ
I think I would prefer a more blueish color (say 6k) but I'm not willing to sacrifice light output for color so I guess OEM 4300K it is. Thanks for your input!
Old 03-25-2012, 03:12 PM   #13
zAnSh1n
♥カレー大好き !!
zAnSh1n's Avatar
Drives: ♿
i had no idea, probably should have searched a bit before posting; things have changed since 2008 [last time i drove] :P
i'm personally going with Phillips 8k...
Old 03-25-2012, 03:25 PM   #14
Dark
Elite Padawan
Dark's Avatar
8000K is not bright. 6000K is okay, but it's hard to see in the rain. The peak is mostly between 4300K-4500K, that's why 4300K being the brightest.
Dark
