Old 03-25-2014, 12:58 PM   #645
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Ocho Seis View Post
sorry heres the first dyno as u can see no issues , so something is going on
boost leak?
glamcem is offline   Reply With Quote
Old 03-25-2014, 02:01 PM   #646
captain_jack
captain_jack's Avatar
Here is the the new dyno with the dip , my first dyno as well let me know if you have any ideas.
I contacted KW they said they had the same issue with there BRZ.
System was full checked for leaks and any other issues , system is leak free ...
Hey I noticed your crossing over to speed density at almost 4.6k, I have mine changing at 3900. I don't have that dip that you do, just the boost leak at around 6.7k and then it climbs back up like yours.
may the schwartz be with you....
Old 03-25-2014, 02:04 PM   #647
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Idk about you all but I can sometimes hear the bypass valve open up top...I don't think it's supposed to do that
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 03-25-2014, 09:29 PM   #648
captain_jack
Im willing to bet if you re dynoed your car you will have the boost dip we do.
sent from your mom
Old 03-25-2014, 09:31 PM   #649
Zach3794
I'm gonna ask bill to post the dyno later anywho. Gotta get the shop to send them over
Old 03-25-2014, 10:46 PM   #650
Zach3794
sent from your mom
Well I asked Bill to send me over some graphs with hp/tq and a boost plot. I should get them tomorrow ish and will post them then.
Also as a little teaser for you guys I asked him to throw in the E85 graph overlaid with hp/tq and boost plot as well.
Old 03-26-2014, 12:49 AM   #651
captain_jack
Hopefully just attaching the file works. One is just my dyno and the second is overlayed with the Jackson kit, same dyno, same tuner, almost the same miss minus a high flow cat on his.[ATTACH]7193[ATTACH]71934
Old 03-26-2014, 06:41 AM   #652
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Bear in mind that those of us who don't know you guys and your cars personally can't possibly keep straight who's done what to whom. Just a nice succinct list of power relevant supporting mods, who tuned it, a tune rev # or date helps a lot.
TIA!
Ralph Spoilsport is offline   Reply With Quote
Old 03-26-2014, 09:27 AM   #653
Ocho Seis
Ocho Seis's Avatar
Drives: 2013 Frs
My mods are , Greddy Evo 3 cat back , Borla uel header , Exedy stage 2 clutch , upgrade , fuel pump , Tuner On point Dyno ,
Car on intail install had no boost leaks , or dips in dyno , car on second dyno showed the dip/ boost leak , system was checked more than once , KW R & D was contacted and they advised that they had the same issue with , there BRZ that they have that they would send me the dyno / data / logs still waiting and still havent gotten an answer , my tuner belives that there might be some internal slipage at that rpm range .
Just kind of strange , that more than one of us with this kit has the same kind of issue .
So I will wait for KW to get back to me , I am in the works on installing a meth kit aswell shortly just to make sure , plus a boost gauge to watch the boost issue if it stays at 1.5 psi then I wont worry to much at this point .
Ocho Seis is offline   Reply With Quote
Old 03-26-2014, 10:43 AM   #654
captain_jack
TIA!
Sorry I had stated a few posts back I believe. Agency header and cat back, dc sports over pipe. Tune date is on the dyno sheet. Tuning done by nelsmar.
Old 03-27-2014, 12:35 AM   #655
Zach3794
Here are my results. Please keep in mind that this particular dyno has a 17% lower reading than the average Dynojet. Bill's car made 201whp stock on E85 on DSport's dynojet and just hours later made 166whp on this dyno. With that said, here you go. I'll work on getting boost plots, but it looks to me like the dip at the top on 91 is not due to boost leak, as it's fine on E85. The reason it dips and cuts short on E85 is from clutch slip.
91 Octane.
Unfinished E85 Tune. The dip at the top is where the stock clutch starts slipping. We had to cut the dyno run short due to this, but it is my firm belief that with a new clutch the power will keep climbing straight to redline.
Old 03-28-2014, 06:26 PM   #656
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Kraftwerks told me the reason why the new tune they sent me didn't idle was because I didn't have the right MAP sensor so they sent me this nice new red MAP sensor. It got to me the next day and just installed it with the new "factory" Skunk2 tune file they had previously sent.
I'm happy to say that it drives a lot smoother around town in the short test drive I took. Looking forward to see how it performs at WOT later on tonight. Very happy with how Kwaftwerks responded to my input here even though it took a little time. Name:  ImageUploadedByTapatalk1396045407.956429.jpg
mit_peid is offline   Reply With Quote
Old 03-28-2014, 06:40 PM   #657
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Kraftwerks Supercharger Owners Thread
I've found them to very helpful
digital_assassin is offline   Reply With Quote
Old 03-28-2014, 11:04 PM   #658
captain_jack
I'm happy to say that it drives a lot smoother around town in the short test drive I took. Looking forward to see how it performs at WOT later on tonight. Very happy with how Kwaftwerks responded to my input here even though it took a little time. Attachment 72252
Whats the difference with this map sensor? I may have missed it but what makes you need this map sensor over the one they sent.
sent from your mom
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
