Old 03-24-2014, 04:22 PM   #29
Racecomp Engineering
Originally Posted by leicaboss View Post
Couldn't we cut our bumpstops for Swift usage? Or perhaps you also sell some bump stops?
You can but it's not exactly the same. If you cut the soft end of the OEM bumpstop you're hitting the harder end with less of a softer progression to that point and it's a little abrupt. Cut the firm end and you run the risk of bottoming the shock too hard without the bumpstop adequately providing protection.
You can do it in a way that "works" but I'll always prefer a whole new bumpstop designed to work as a whole piece. We unfortunately do not sell our separately.
- Andy
Racecomp Engineering is online now   Reply With Quote
Old 03-24-2014, 04:26 PM   #30
Originally Posted by was385 View Post
As much as I love the springs, I would seriously look into how much time (and cost if you pay someone else) those bushings take to install and adjust before going that route. Scared me off.
This is valid...we've seen a few horror stories from shops that mess it up. Done properly, I think it's the way to go for rear camber adjustment as replacing that upper bushing with something firmer makes a strong difference in feel/handling in addition to the camber adjustment.
But...things aren't always done properly and just doing an LCA is fine too (or nothing at all, but I'm anal).
Whiteline makes a non-adjustable bushing there that still needs to be pressed in, but it's less likely to be a screwed up install. That plus maybe the Whiteline LCAs would be a good way to go.
But just the LCAs would be fine too.
- Andy
Old 03-24-2014, 04:34 PM   #31
was385
Drives: MT WRB BRZ Limited, 2007 911s
- Andy
Yeah, at least for my application, the natural camber from the lowering was perfectly fine for AutoX and DD duty. Ideally, it would be the same on both sides but it's just not worth the time or energy to me. Obviously everyone's application and preferences are different though.
was385 is offline   Reply With Quote
Old 03-24-2014, 04:37 PM   #32
Yup, without anything you do end up in the range of where you should be anyway.
- Andy
Old 03-24-2014, 08:06 PM   #33
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by Wepeel View Post
2nd'd. BRZ stock ride frequencies should be in the 1.4-1.5 Hz range, front and rear.
@racecomp_engineering
I found a couple mistakes in the formula, and my numbers are closer to those in the thread you linked, but still not exact.
Not sure what's different. Feel free to take a look, if my formula is off, I'd like to get it corrected.
Old 03-24-2014, 09:59 PM   #34
Turdinator
Señor Member
Turdinator's Avatar
http://www.ft86club.com/forums/showp...9&postcount=34
It may have settled a small amount since this picture was taken but that's about the ride height. For me I'm not a fan of a huge drop, was interested in performance first and foremost, and didn't want something that was too low and would kill my struts overnight, so this was the easy answer.
What offset are your RPF1s?
1974 TA22 Celica
2013 86 GT
Old 03-24-2014, 10:01 PM   #35
was385
17x8 +45 maxed out oem camber bolts and no rubbing, though the clearance is tight.
The Following User Says Thank You to was385 For This Useful Post:
Turdinator (03-24-2014)
Old 03-31-2014, 09:27 PM   #36
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Ended up going with the eibach pro kit
TwoFourFive is offline   Reply With Quote
WTB: CG SPRINGS Asian Delight Brakes, Suspension, Chassis 0 12-30-2013 06:28 AM
FS: Brz springs hanabie Brakes, Suspension, Chassis 1 09-19-2013 02:16 AM
Best value springs? hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 06-15-2013 12:45 AM
Which of the three springs? the Red Devil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-19-2013 04:31 PM
BEST SPRINGS? whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 10-10-2012 05:50 PM
