Old 03-24-2014, 12:14 AM   #1
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
which springs to buy??
looking for a clean look but not looking to have to worry about rubbing or anything.. which springs you guys think will look and work the best.
I am on 17x8.25 XXR 527s +35
TwoFourFive is offline   Reply With Quote
Old 03-24-2014, 12:34 AM   #2
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
H&R's sports or super sports depending on how low you want to go. I have the sports and they feel super comfortable, like stock but better feel. I've ridden on eibachs pro kit and sportlines, they feel alright, but can get pretty bouncy. I havent really experienced other springs, but I'd recommend H&R's unless you like bouncy ride
Old 03-24-2014, 01:01 AM   #3
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I wasn't happy with Sportlines. I love the looks of the Pro-Kit, but I've never driven on them. Sportlines were way too harsh for me.
ericmpena is offline   Reply With Quote
Old 03-24-2014, 01:03 AM   #4
TwoFourFive
Drives: 13 HOT LAVA
That's what I have been hearing. I don't think 1" will be enough drop for me though. I have not seen pro kits on 17s only on 18s. Does anyone have pictures of them on 17s
Old 03-24-2014, 01:24 AM   #5
ericmpena
ericmpena's Avatar
If you're looking for more drop than 1" then you're going to need rear LCA's as well. Also, I'm pretty sure you're going to sacrifice a good amount of ride quality in the process.
While that may not seem important right now, trust me, once you start bouncing around for the slightest bumps on the road you're really not going to enjoy driving anymore.
You'll be putting a good amount of strain on your stock struts with your car lowered more than 1". You should just upgrade the struts along with the lowering springs at the same time, or just get coilovers.
I always heard that from everyone and it was so annoying. "Just get coilovers." No one really wants to spend $1,200+ on coilovers when you're just trying to get rid of wheel gap...but in the long run it's the better decision that will save you money later on. What happens if you decide you don't like the drop or ride quality of your springs? You're going to lose a good amount of money trying to figure out what works best for you. Coilovers are adjustable....so it's not going to cost you anything else to adjust the damping or ride height.
In my case I spent $230 on Sportlines, $200ish on rear LCAs, $450 for springs installation/rear LCA installation/alignment, and then $200 for wheel spacers so that the stock wheels weren't so tucked in. All together it turned out to be a $1000 project. Let's just say after 5 months I didn't like the look of the Sportline drop, nor the ride quality. I purchased a Pro-Kit for $230 and was about to get them installed for $300 including alignment. That would've put me out $530...totaling the cost to $1530 to still get a setup that I'm satisfied with. Lol
You can see why it would've been better to just get coilovers from the beginning.
Anyways, that's my advice. If you want to save a good amount of money then go with something that's about a 1" drop. With a 1" drop you won't need rear LCA's. That'll save you $200 at least for those, plus save you the cost of having to get those installed if you're paying someone to do that for you.
With a Pro-Kit you should just need the springs, front camber bolts ($20), and then install. You should have a good ride quality with a mild drop. Anything more than that and you're better of with coilovers IMO.
The Following User Says Thank You to ericmpena For This Useful Post:
TwoFourFive (03-24-2014)
Old 03-24-2014, 01:27 AM   #6
TwoFourFive
Drives: 13 HOT LAVA
Well said.. That's probably what I am going to to do. Thanks so much
Old 03-24-2014, 01:27 AM   #7
ericmpena
ericmpena's Avatar
Sorry for the previous long response. Here's a link to a Pro-Kit on stock 17's.
http://www.ft86club.com/forums/showthread.php?t=26769
Old 03-24-2014, 01:31 AM   #8
TwoFourFive
Drives: 13 HOT LAVA
So all i will need is the springs correct. Will I also need to purchase spacers or anything?
Old 03-24-2014, 01:37 AM   #9
ericmpena
ericmpena's Avatar
SPC Front Camber Bolts $25: http://www.ebay.com/itm/like/271353238922?lpid=82
Wheel Spacers (Optional): http://www.b2autodesigns.com/index.p...1129_1216_1341
You can probably tell right now that the wheels sit pretty far inside of the wheel fenders. When you lower your car it's going to be much more obvious. A lot of people want the wheels to be flush with the fender and not be tucked in. If you want that look then you'll want to get 20mm spacers for the front, and 25mm spacers for the rear (For stock wheels). You can find them for sell used on the Member's Classifieds...or just buy them from B2 Auto. They're the cheapest I've found. Before I stumbled upon B2 Auto I was almost about to purchase spacers from Eibach which were $200 for 2 as opposed to $200 for the set of 4!
If you have aftermarket wheels with a good offset (they already sit flush with the fender and aren't as tucked in as the stock wheels) then you won't need spacers. Some people have gone without the front camber bolts as well, but I'd say just get them. They'll help with your alignment and they're only $25.
Old 03-24-2014, 01:40 AM   #10
TwoFourFive
Drives: 13 HOT LAVA
Okay cool thanks so much for the help.
Old 03-24-2014, 06:40 AM   #11
Gunman
Drives: 2019 Mazda Miata RF
If you want to geek out on some spring numbers:
https://drive.google.com/file/d/0B00...it?usp=sharing
Gunman is offline   Reply With Quote
Old 03-24-2014, 09:34 AM   #12
Racecomp Engineering
Something is wrong with your ride frequency numbers.
- Andy
Old 03-24-2014, 12:49 PM   #13
Gunman
- Andy
Any thoughts on what? Spread sheet should be shared, and editable. I just ask that you note what was changed, why, etc.
Old 03-24-2014, 01:18 PM   #14
FR-Slide
Drives: 13 Whiteout 6MT
No mention of RSR or Swift? I was pretty much sold on the Swifts, but there seem to be so many opinions here. This would be for DD and maybe canyon use, not track time.
Where would you rank RSR or Swift to Eibachs/RCE? What about Hotchkis or Tein?
Edit: and a follow-up! I'll be running stock wheels for a bit, so was going to get spacers. I don't want to make them hellaflush or anything, was thinking 15f/25r. I know B2 is a vendor here, but is there anything wrong with just getting hubcentric spacers off of like Amazon?
FR-Slide is offline   Reply With Quote
WTB: CG SPRINGS Asian Delight Brakes, Suspension, Chassis 0 12-30-2013 06:28 AM
FS: Brz springs hanabie Brakes, Suspension, Chassis 1 09-19-2013 02:16 AM
Best value springs? hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 06-15-2013 12:45 AM
Which of the three springs? the Red Devil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-19-2013 04:31 PM
BEST SPRINGS? whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 10-10-2012 05:50 PM
