Which of the three springs?
Hello all members,
I have a simple question and need an opinion. Which of the three following springs should I go with? Remember all I want is suggestions on the springs and not coil-overs. thanks. And now the springs in no particular order:
![]() Also what else should I get. Just want some wheel gap gone and a small improvement. No track days for me.
Salmon, the other Pink Meat!
Swift. If you're wiling to spend a little more, TRD.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread Last edited by DSOmegaX; 03-17-2013 at 09:53 PM. |
Drives: Asphalt FR-S
I have the hotchkis springs. Feels very similar to stock ride quality. Very pleased with the small change in handling - a little more neutral at the limit.
Had RCE dropped the price of their springs a month earlier than they did, I would have likely gone with them. |
Drives: YUZU FR-S RS 1.0 & AE86 Hatch
"...the expression of the love in my eyes for my new RS 1.0 is the exact parallel opposite of bitterness, and hate of all the other FR-S owners that want one but won't admit that they do. " ~idreamofdrifting~
"...the main reason people swap (from Scion to Toyota badges) IMO, is because they're embarrassed at the Scion stigma they themselves are perpetuating..." ~Sho220~ |
Thanks for the response. Aren't the TRD Springs about four hundred. That is crazy money for springs that yield very similar results as two hundred Dollar springs. I could be wrong.
Drives: 2013 Scion FR-S MT "Panda"
#7 | |
I can't say for sure as I have the STI, but since I don't think there are any differences between the two, they should. Turn in is a lot more responsive and the car feels more stable with less roll in the corners. Both STI and TRD springs are designed to work with OEM shocks so you don't need to change them out.
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
Drives: 2013 - Scion FR-S in White"red"out.
I've been thinking about these H&R ones:
http://www.perrinperformance.com/brz...-sport-springs I live in the same town as Perrin and they carry these and speak very highly of them. Anyone running them yet?
Of the those, our RCE Yellow springs are the only ones that include shortened replacement bumpstops. The others are fine springs but the replacement bumpstops are big deal since the car is already pretty close to them on the stock springs.
We're also the only company to offer even spring rates front to rear, with a lot more rate up front especially. This doesn't mean understeer....it means quicker turn-in, good balance, and ability to power out of corners plus still rotate the car as needed. Rather than corner on the bumpstops up front we prefer to let the spring do the work. The medium/mild drop also helps by keeping geometry and bump travel in check, so you get good ride and handling. - Andrew |
#10 | |
Andrew, what else will I need to get the car back to spec (alignment) after the spring install. In other words, what do you recommend now that I have a shipment/parts coming to me.
#11 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
+1 for RCE Yellows, best spring for the OEM struts.
#12 |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
I have the Hotchkis too. Love them! They ride near stock quality, but handle so much better.
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#13 | |
We do offer our "starter kit lite," which adds camber bolts up front and the Whiteline rear camber bushing to add camber adjustment front and rear. This lets you dial things in a little better for performance (without a tire wear penalty) and make things just a little mo' better. Many just go with the springs, and some just go with the front camber bolts since they're only 10 bucks and easy to install. All of the above are good solutions...I would at least get the front camber bolts. - Andrew |
#14 |
Drives: LS Swapped BRZ
I love my RCE yellows even more after autoxing last sunday :-)
| All the different springs... | Skurj | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 03-29-2013 06:49 AM |
| Anyone use the JDM/Sti springs? | G4mb17 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-25-2012 08:10 PM |
| HELP:Q about springs | Obja | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 10-08-2012 02:12 PM |
| trd springs or no? | FT86R | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 09-30-2012 03:52 PM |
| STi Springs | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-14-2012 01:19 PM |
