Old 03-24-2014, 01:22 PM   #15
Wepeel
Drives: '13 BRZ Ltd
Something is wrong with your ride frequency numbers.
- Andy
2nd'd. BRZ stock ride frequencies should be in the 1.4-1.5 Hz range, front and rear.
Wepeel is offline   Reply With Quote
Old 03-24-2014, 01:25 PM   #16
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by FR-Slide View Post
Where would you rank RSR or Swift to Eibachs/RCE? What about Hotchkis or Tein
From my experience with Eibachs,
What i have read about RCE & RS*R's & Swifts and the rest, Id say:
RCE=Swift>RS*R>Eibachs=HKS>Tein
Old 03-24-2014, 01:38 PM   #17
FR-Slide
Drives: 13 Whiteout 6MT
Aren't RCEs made by Eibach though? So are you saying that their particular rates are better than what is available in the Pro-kit or Sportlines?
FR-Slide is offline   Reply With Quote
Old 03-24-2014, 01:54 PM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Yes. The only experience I have had with Eibachs was a Pro-Kit on my last car, they were nice, but a bit crashy for my taste, IMO.
RCE and Swift provide more of a performance related spring than a lowering spring, (like 20 mm lower than stock)
Whereas RS*R is a blend of asthetics and performance (25-35mm lower than stock). The spring rates are in that little google doc higher up
Old 03-24-2014, 02:11 PM   #19
Eibach does make our springs for us...made to our specs with our own spring rates and drop. They're great to work with and make a quality spring (made in the USA). But they're definitely "our" springs.
We actually had our first prototype spring on a test car before the car was even released here in the states. That was fun.
I highly recommend a spring that comes with replacement bumpstops. Sportlines IMO are too low but I think Pro-kits are fine springs. Swift BRZ rates are fine, but I wish they included bumpstops. Still a quality spring.
Anything that lowers more than inch is making sacrifices for looks, even if you replace the struts.
- Andy
Old 03-24-2014, 02:15 PM   #20
Originally Posted by Gunman View Post
Any thoughts on what? Spread sheet should be shared, and editable. I just ask that you note what was changed, why, etc.
http://www.ft86club.com/forums/showthread.php?t=26661
That thread has what I recall are the right numbers (there's a typo where he listed FR-S rear twice, the lower number is supposed to be BRZ).
The ride frequency is what you are after.
- Andy
Old 03-24-2014, 02:21 PM   #21
was385
Drives: MT WRB BRZ Limited, 2007 911s
No mention of RSR or Swift? I was pretty much sold on the Swifts, but there seem to be so many opinions here. This would be for DD and maybe canyon use, not track time.
Where would you rank RSR or Swift to Eibachs/RCE? What about Hotchkis or Tein?
Edit: and a follow-up! I'll be running stock wheels for a bit, so was going to get spacers. I don't want to make them hellaflush or anything, was thinking 15f/25r. I know B2 is a vendor here, but is there anything wrong with just getting hubcentric spacers off of like Amazon?
A bunch of people I very much trust in terms of performance setups steered me to the RCE Yellows. I finally got a chance to install them a couple of weeks ago and I couldn't be happier. They soak up small bumps in the road better than the stock springs and keep you very flat through the corners. The amount it cut down on my body roll in AutoX is incredible.
was385 is offline   Reply With Quote
The Following 3 Users Say Thank You to was385 For This Useful Post:
fooddude (03-24-2014), Mike86 (03-24-2014), Racecomp Engineering (03-24-2014)
Old 03-24-2014, 03:26 PM   #22
FR-Slide
Any pics of the after shots? I'd like to see the amount of drop if possible.
Old 03-24-2014, 03:34 PM   #23
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
- Andy
Couldn't we cut our bumpstops for Swift usage? Or perhaps you also sell some bump stops?
leicaboss is offline   Reply With Quote
Old 03-24-2014, 03:37 PM   #24
was385
http://www.ft86club.com/forums/showp...9&postcount=34
It may have settled a small amount since this picture was taken but that's about the ride height. For me I'm not a fan of a huge drop, was interested in performance first and foremost, and didn't want something that was too low and would kill my struts overnight, so this was the easy answer.
Old 03-24-2014, 03:37 PM   #25
2pt5RS
Berz
I'm glad to see that @Racecomp Engineering is all over this thread. They're the springs I'm going to buy when it comes time to upgrade.
http://www.racecompengineering.com/i.../brz-lite.html
2pt5RS is offline   Reply With Quote
The Following User Says Thank You to 2pt5RS For This Useful Post:
Old 03-24-2014, 03:48 PM   #26
was385
As much as I love the springs, I would seriously look into how much time (and cost if you pay someone else) those bushings take to install and adjust before going that route. Scared me off.
Old 03-24-2014, 03:50 PM   #27
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
I don't think the bushings are necessary (could be wrong though) and I'm a big fan of doing stuff right the first time, having learned the hard way about the alternative.
XanRules is offline   Reply With Quote
Old 03-24-2014, 03:58 PM   #28
was385
Yeah, with just the springs, I've got rear camber of -1.9 on one side and -2.4 on the other. Perfectly fine IMO.
WTB: CG SPRINGS Asian Delight Brakes, Suspension, Chassis 0 12-30-2013 06:28 AM
FS: Brz springs hanabie Brakes, Suspension, Chassis 1 09-19-2013 02:16 AM
Best value springs? hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 06-15-2013 12:45 AM
Which of the three springs? the Red Devil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-19-2013 04:31 PM
BEST SPRINGS? whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 10-10-2012 05:50 PM
