| Northern California NorCal |
#15 |
Dismember
Drives: 2013 Red Scion FR-S
The pedal travel is moved lower. The engagement point relative to pedal movement from its resting point remains the same. Before and after the mod, you disengage the clutch by pushing all the way down. There's a lot less distance to travel for the mod. Then you engage by lifting all the way off. Again, a lot less distance to travel. Unfortunately both ways are imperfect. I want the engagement point moved down while still having some freeplay above the engagement point. I'd also like a quicker engagement, but there's supposedly delay valves built into the master and slave cylinders. I have a lot of trouble driving smoothly as i have to engage so slowly.
#16 |
Drives: 2013 Ultra Marine Blue FR-S
| The Following 2 Users Say Thank You to dun3 For This Useful Post: | CamryDS (04-06-2013), chotemaamu (04-03-2013) |
#18 | |
Drives: 2013 BRZ Limited
![]() did make the car smoother to shift... until the pedal didn't spring back. |
#19 |
Drives: '13 Raven FR-S, MT
Sorry to revive this, but I just removed the helper spring on the clutch on top of already having my pedal adjusted from before -- HUGE difference, feels like a real clutch now. The grabbing point is a little higher, so I adjusted it to be even lower. Several people have removed these helper springs from other forums/cars, no issues from what I've researched. Can't imagine it doing any damage to ours.
.ck |
#20 |
Drives: 2014 SWP BRZ Limited
I still need to do this but I just haven't had any time. I don't want to screw anything up and have it basically riding the clutch.
#21 | |
.ck Sent from my HTC One using Tapatalk |
| The Following 2 Users Say Thank You to ck-GT86 For This Useful Post: | Mini Cooper S (08-12-2014), SOLDIER [X] (03-04-2014) |
#22 |
Drives: 2003 Camry Blue | 2013 FR-S White
This is one of the easiest modifications there is. I've driven the car about a year with it -- no clutch burns nothing. Biting point moved and am VERY happy with it -- though I didn't do much of an adjustment to the clutch, just about 1-2mm above the brake pedal, I didn't need it that low.
| The Following User Says Thank You to CamryDS For This Useful Post: | SOLDIER [X] (03-04-2014) |
#23 | |
#24 |
RIP Buzz 8/5/14
Drives: a moneypit
this was the 1st thing i did after i bought my brz in july
![]() wasn't too hard, just had to play with where it felt comfortable to me
#25 |
Drives: 2013 BRZ Limited, WRB, 6MT
Would anyone like to do this for me please? I don't mind driving to the Bay Area
Of course I'll pay or buy food for taking the time to do this. Thanks!
#26 | |
Drives: 2013 FR-S, 2008 Fit
Same goes to any of you in the Sac area who need this done. |
| The Following User Says Thank You to mitosis For This Useful Post: | Byoki (03-05-2014) |
#27 | |
| Gas Pedal Adjustment | ML | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 05-01-2017 09:26 PM |
| Clutch Adjustment Issues!! | FT-86- | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 05-28-2015 09:29 PM |
| Quick Question when doing clutch Adjustment | Number 6 | BRZ First-Gen (2012+) — General Topics | 3 | 03-13-2013 11:18 PM |
| Quick Question when doing Clutch Adjustment | Number 6 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 03-09-2013 04:31 PM |
| Clutch Pedal Engagement Adjustment | denverizzles | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-25-2012 05:01 PM |
