Old 11-21-2012, 09:58 AM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Gas Pedal Adjustment
Are there any suggestions on how to adjust the gas pedal to be "even" with the brake pedal? The Gas sits so much further down than the brake (1.5 inches ). I put on a SRP Heel toe pedal last night and want to adjust height. Yes I searched.
Old 11-21-2012, 11:13 PM   #2
normancw
normancw's Avatar
Drives: 128i
How do you like the SRP pedal? How thick is it (i.e., how much higher does it make the pedal)? Did you just get the gas pedal?
Thanks
normancw is offline   Reply With Quote
Old 11-22-2012, 08:09 AM   #3
wparsons
wparsons's Avatar
Do you mean vertical height, or depth? I find under hardish breaking the gas pedal is in close to the perfect spot depth wise. If the brake and gas are even at rest, then under braking the gas is closer and a real pain to heel/toe with.
flickr
Old 11-22-2012, 10:47 AM   #4
ML
ML's Avatar
The srp pedal is very nice high quality made to order. Heel toe is 90% better imo. I want the gas pedal to come towards me about a half inch. I get what you are saying about when they ate both being pressed but I still think the gap coyld be smaller.
The Following User Says Thank You to ML For This Useful Post:
normancw (11-22-2012)
Old 11-22-2012, 11:48 AM   #5
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Interesting that you want it closer to you and I want it a little further away. I have SRP pedals too and I find the height perfect for heel-toe around town (I actually just do it out of habit, not because I need to).
But, on the track, with harder braking, the gas pedal is sitting too high to heel-toe perfectly. And it's on the track that I really want it smooth.
I don't know of any way to raise it without a spacer under the SRP plate. (Gas pedal for you, brake pedal for me). But, if you find a way to adjust it, please let me know.
Thanks
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
The Following User Says Thank You to Slartibartfast For This Useful Post:
Old 11-22-2012, 11:57 AM   #6
normancw
normancw's Avatar
Drives: 128i
Thanks for the info! I ordered just the gas pedal. Looking forward to it. I've gotten used to heel and toeing in the FR-S, but it's a bit hard on my ankle!
Old 11-22-2012, 12:06 PM   #7
Slartibartfast
Klaatu barada nikto
I love mine. Great customer service from the company too.
Old 11-24-2012, 04:27 AM   #8
Yruyur
Yruyur's Avatar
For the life of me I can't find the gas pedal when trying to heel toe. Going to have to research this.
Sent from my flux capacitor using Taptalk
Old 11-24-2012, 07:17 AM   #9
ML
ML's Avatar
Do you use the true heel toe method or the half n half method as I do. (half of your foot on the gas and half on the brake while your foot is straight up and down)
Old 11-24-2012, 09:29 AM   #10
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
Alright.. I'm willing to share my secret.. I too have the SRP heel-toe pedal and I love it!
Here's how you RAISE the gas pedal- I've been meaning to put this in the DIY section for months, but been a little lazy about it..
1. Remove the gas pedal assembly by removing the 2 nuts
2. You'll notice there is some slack on the 2 threads that the bolts were on
3. This slack allows you to put spacers to raise the gas pedal ~1cm
4. Reinstall gas pedal assembly
Done.. 1cm makes A TON of difference for heel toe.. It actually made it too easy because I'd find myself blipping the throttle with regular braking. If you guys need help with visualizing this mod- I'll post a DIY.
TyperRspec789 is offline   Reply With Quote
The Following 4 Users Say Thank You to TyperRspec789 For This Useful Post:
Black Tire (05-10-2013), funbeatsfast (01-28-2013), ngabdala (11-24-2012), Yruyur (11-24-2012)
Old 01-28-2013, 06:49 PM   #11
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
I tried adjusting the brake and clutch pedals first. Now it's almost perfect.
funbeatsfast is offline   Reply With Quote
Old 01-28-2013, 08:14 PM   #12
Nardi330
Nardi330's Avatar
Drives: 86
fitted the cusco throttle pedal and it raised the throttle slightly while bring it closer to the brake pedal for better heel/toe:
Nardi330 is offline   Reply With Quote
Old 02-26-2013, 11:52 PM   #13
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
did you need to drill into the factory pedal to fit it, or were there brackets behind it which simply clamps onto it?
Fizz is offline   Reply With Quote
Old 02-27-2013, 12:14 AM   #14
Nardi330
Nardi330's Avatar
Drives: 86
for the Cusco one, no need to drill anything. completely reversible.
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Rear camber adjustment options? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 09-12-2012 10:46 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
