Northern California NorCal
Old 03-15-2013, 02:19 AM   #1
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Clutch Pedal Adjustment?
Did you Bay Area people do your clutch pedal adjustment yet? I'm thinking of offering it as a service. I've been under there five times so far to get it right. It's getting to be second nature.
Old 03-15-2013, 02:26 AM   #2
PMok
Codename: Stitch
PMok's Avatar
I attempted to do it once, but found the 14mm (or was it 13mm) wrench I had was too long to let me do it... then I decided to leave it be and learn to shift/clutch with it as it was... the higher engagement point lets me just quickly stab the clutch when making shifts, in theory making the shifts faster.
But yeah climbing down there is a bit awkward... I almost got stuck down there and took some effort to get myself back out.
The Following User Says Thank You to PMok For This Useful Post:
BRZkitty (03-05-2014)
Old 03-15-2013, 02:53 AM   #3
EAGLE5
Dismember
EAGLE5's Avatar
The $7.99 metric set from Sears just barely fits there. A shorty would make it much easier. 12mm for the clutch and 14mm for the sensor. I find it 1000 times easier to shift now. It's unbelievable. I did have it a bit low at first, so I just moved it up. When it was too low, shifting into reverse was hard when cold. Now, a little bit below the brake, it all works great.
Old 03-19-2013, 12:37 PM   #4
EAGLE5
Dismember
EAGLE5's Avatar
I keep adjusting and readjusting, trying to find the perfect spot. I think I have now. If you go to low, the pedal will not spring back fully into position. I've now set the pedal exactly at the lowest point where it will still spring back.
Old 03-19-2013, 01:00 PM   #5
dun3
dun3's Avatar
Drives: 2013 Ultra Marine Blue FR-S
want! How about I buy you a 6 pack
dun3 is offline   Reply With Quote
Old 03-20-2013, 02:52 AM   #6
EAGLE5
Dismember
EAGLE5's Avatar
I am not such an easy date! Instead, buy me one of these or one of these (or any super short 12mm) to make the job easier. Also bring something like these (notice 3/8" thick... 1/4" may work, about 10mm diameter, and self-adhesive) to make adjusting the sensor a snap. Then you've got a deal.
My stinky socks may also hit your ceiling, just a warning.
Old 03-20-2013, 04:00 AM   #7
dun3
dun3's Avatar
I think we might have a date.. Gimme some time though.. I may get a little lazy, but I wanna try this out! Will pm you, thanks much!
Old 04-01-2013, 09:49 AM   #8
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
shorty's go for 7.99 at your local walmart -- pack of 12 -- bought my set, going to try. I'm 6'4" and i'm not a contortionist, so I might hit you up and just give you my 9 piece set =).
CamryDS is offline   Reply With Quote
Old 04-01-2013, 12:12 PM   #9
strat61caster
strat61caster's Avatar
Why would you want the engage point lower? Then it just takes longer to shift gears...
Can someone explain?
ineedyourdiddly
Old 04-01-2013, 12:23 PM   #10
CamryDS
I'm not sure about others, but right now my foot raises too high when I let go of the clutch and it causes the feeling of shifting in and out of gear to feel unnatural.
I'm coming from driving a celica and the celica's shifting feels way more natural as it's pedals are lower and biting point is lower. If this adjustments makes it feel like the clutch engagement is lower than the previous point, it should shift the same way, just engage at a lower point. Right now my left leg lifts way too high when I shift and it's caused me to stall my car more than I want (which is anywhere above 0).
The Following User Says Thank You to CamryDS For This Useful Post:
strat61caster (04-01-2013)
Old 04-01-2013, 01:00 PM   #11
strat61caster
So once you hit the full engagement point you just slide your foot off the pedal and let it snap up on it's own because you don't need that last bit of travel?
ineedyourdiddly
Old 04-01-2013, 01:10 PM   #12
CamryDS
Once the biting point/engagement point is met, (from my teacher) you're suppose to pause for a moment then slowly disengage the clutch. Slowly can go from anywhere of 3 seconds to 1/2 a second, depending how advanced you are at driving.
Even with the slow disengaging I'm still lifting my foot off way too far and the engagement point is way too high for me to be comfortable and the car hesitates in shifting.
Old 04-01-2013, 02:44 PM   #13
strat61caster
Gotcha, entirely preferential.
Thanks.
ineedyourdiddly
Old 04-01-2013, 02:48 PM   #14
CamryDS
Thanks.
You're correct, entirely preferential -- no real need to do this =)
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 09:26 PM
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 09:29 PM
Quick Question when doing clutch Adjustment Number 6 BRZ First-Gen (2012+) — General Topics 3 03-13-2013 11:18 PM
Quick Question when doing Clutch Adjustment Number 6 Scion FR-S / Toyota 86 GT86 General Forum 2 03-09-2013 04:31 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
