#15 |
Drives: 2017 86
#16 |
Drives: 2013 SWP BRZ
The older STi's also have a bunch of bolts you need to remove to pull the pump out, which ended up being a PITA because they were very fragile...but how are you going to compare an EVO to this car which is completely different??
lol
#17 |
NASA SpecE30 Racer
There is no way anyone has swapped a fuel pump in a BRZ/FR-S in 15 minutes.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#18 | |
Seems Legit
Drives: Toyota
FRS w/ Greddy Turbo Kit and custom tuned
Holy incorrect information. There's no need for the OP to change his fuel pump if his tuner didn't tell him it was necessary. You need to push this platform beyond what he's running to necessitate a fuel pump change, especially given the fact the kit was designed using the stock fueling. Greddy's stance is if it ain't broke, don't fix it. There's no need in adding variables that aren't necessary. For a first timer changing the fuel pump on this platform they should dedicate at least an hour and that's if they get the factory sock and o-ring song and dance correct on the first attempt and then there's the pesky gasket to contend with and the cutting of the factory fuel filter from the fuel pressure regulator clip. Any screwup in assembly can lead to a drop in fuel pressure which can be catastrophic. There are certainly not 5 bolts and it's not a simple plug and play job. There's only 1 bolt, the bolt holding the rear drivers seat down and that's the easiest part of the job. Personally, if the OP didn't install the fuel pump prior to tuning, such that any incorrect installation would be caught on the dyno, I wouldn't bother with it. I'd go with larger injectors, which require scaling and retuning, before I touch the pump. It's simply not necessary for most base kits on this platform running pump gas.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#19 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
What's an frs baseline on this dyno?
#20 |
Big in Japan
Drives: turBRZ
Nice! I'm interested to hear about your experience with TSM. They're the closest, most well known tuner in my area but I am a bit hesitant to use them.
#21 | |
Drives: WRB Subaru BRZ Limited
| The Following User Says Thank You to buddy32 For This Useful Post: | GTHachiRoku (01-16-2014) |
#22 | |
Drives: 2017 86
I just saw the sending unit etc and it looked really similar. Regardless, you just pull the back seats out and it's right there. |
#24 | |
Seems Legit
Drives: Toyota
I've ran 540cc injectors and 770cc injectors on 93 octane and haven't neared the point where I'll have to replace the pump. I've replaced the pump just to mess with it for a dw65c and swapped back to stock. For awhile I had 2 canisters that I would go back and forth with while testing. The dw65c is a decent pump, however the pump on this platform isn't a slouch nor is replacing it child's play. Search on this forum and you'll find examples of people who had problems with replacing the pump and those who loss fuel pressure due to incorrect installations. If you're saying rather "safe than sorry", any fuel pump can go out, whether stock or aftermarket. In some instances, built motor, flex fuel, etc. the pump may well need to be changed. However, where the bulk of the FI owners will be, it doesn't. Change the port injectors under the hood, leave your back seat alone, drive sideways and smiling.
#25 | |
Drives: 2008 Toyota Prius, 2012 911 Turbo
Sorry, off topic. Last edited by LBC Por Siempre; 01-17-2014 at 10:38 AM. |
#26 |
#27 |
Drives: 2013 Black FR-S
Evassive Motorsports tuned one to 270 whp on 91 CA piss gas. That is pretty darn good. Looks like you can get an estimated extra 20-30 whp with oh-so-sweet 93 octane!
| The Following User Says Thank You to sw20kosh For This Useful Post: | midnight23 (01-20-2014) |
#28 | |
Drives: 2017 86
| ImperiousRex Time Attack BRZ **Evasive Tuned 271whp Greddy Turbo** | Evasive Motorsports | BRZ Photos, Videos, Wallpapers, Gallery Forum | 18 | 07-24-2014 07:38 PM |
| Midnight23 White on White Greddy Turbo Kit 275whp ***Evasive Tuned*** | Evasive Motorsports | BRZ Photos, Videos, Wallpapers, Gallery Forum | 18 | 07-15-2014 10:39 PM |
| ImperiousRex Time Attack BRZ **Evasive Tuned 271whp Greddy Turbo** | Evasive Motorsports | Forced Induction | 21 | 02-07-2014 11:12 AM |
| Midnight23 Greddy Turbo Kit 270whp ***Evasive Tuned*** | Evasive Motorsports | Forced Induction | 27 | 01-27-2014 01:51 AM |
| Greddy Turbo kit tuned by R/T Tuning (320hp) | R/T Tuning | Forced Induction | 37 | 12-14-2013 04:16 PM |
