Old 01-10-2014, 02:10 PM   #15
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Originally Posted by sw20kosh View Post
Evassive said:
so 7 psi creeping up to 9-10 psi
So im guessing they had to install a modified actuator then right? The kit wont let you go past 7psi! It opens the wastegate. And what does he mean w better airflow? Does he mean the exhasut mods are making it creep up? Im a noob... Excuse my nubiness
Pablitomarrero is offline   Reply With Quote
Old 01-10-2014, 02:12 PM   #16
sw20kosh
Drives: 2013 Black FR-S
No, same actuator. Just because a wastegate is rated to 7 psi doesn't mean it will hold 7 psi.
If the wastegate is too narrow/small it won't be able to vent the necessary exhaust gas which will allow all that extra gas to go through the turbo's turbine. This causes higher boost pressures than desired and manifests as "creep". The solution is A. run a higher wastegate spring (if you are ok with the higher psi level) or B. enlarge the wastegate (which is hard to do on an internally gated turbo).
When you free up the exhaust significantly, you increase the efficiency of the turbo and you may gain some psi from that.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
diss7 (02-01-2014), Pablitomarrero (01-10-2014)
Old 01-10-2014, 02:15 PM   #17
Pablitomarrero
Ah i understand . Thank you. At least I havent observed any creep in mine, my gauge reads 7 maybe 8 at some point almost redline. Anybody know exhasut diameter @midnight23 is running?
Old 01-10-2014, 02:19 PM   #18
sw20kosh
Also, exhaust diameter is only one thing. You have to look at:
1. # of exhaust bends
2. bend angles
3. are the pipes mis-aligned at the flanges causing turbulence
4. type of muffler
My guess (if your exhaust is adequate) that the discrepancy in power between the two of you is primarily tuning based and also the extra 2-3 psi.
The Following User Says Thank You to sw20kosh For This Useful Post:
midnight23 (01-10-2014)
Old 01-10-2014, 02:22 PM   #19
Pablitomarrero
2. bend angles
4. type of muffler
I am also running a high flow cat so that probably has an effect on my overall #'s... Positives of this is my car doesnt stink lol
Old 01-10-2014, 04:10 PM   #20
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
2.5" straight no cats / resonators to 2.75" catback
Psi 10-11
Build Thread
Instagram
The Following User Says Thank You to midnight23 For This Useful Post:
Old 01-10-2014, 04:52 PM   #21
Pablitomarrero
Psi 10-11
Awesome that means I have potential . Did they switch out the wastegate for a higher one? Or is it the boost creep
Old 01-10-2014, 07:37 PM   #22
midnight23
Nope turbo is unmodified it's just tuning and boost creep
Build Thread
Instagram
Old 01-10-2014, 08:30 PM   #23
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
hey man nice to meet you today, your car is pretty dope i'm jealous
SoCal909 is offline   Reply With Quote
The Following User Says Thank You to SoCal909 For This Useful Post:
Old 01-10-2014, 09:17 PM   #24
midnight23
Appreciate it, enjoy your coils!
Build Thread
Instagram
SoCal909 (01-10-2014)
Old 01-25-2014, 08:58 AM   #25
Pablitomarrero
Midnight23 Greddy Turbo Kit 270whp ***Evasive Tuned***
@midnight23 Whats your average mpg at? Have you noticed significant gas cosumption with the larger injectors/fuel pump?
Old 01-25-2014, 03:21 PM   #26
midnight23
Surprisingly enough I'm getting better mpg than my NA setup. I average 30-32 highway so far that is with 4 pulls. It's really great ! I was using a 1/4 tank to go to LA and back and now it's less than that.
Build Thread
Instagram
Old 01-26-2014, 12:27 AM   #27
Pablitomarrero
really? awesome. Thats more or less what im getting. I guess you only use up alot more gas at WOT
Old 01-27-2014, 01:51 AM   #28
midnight23
Yea I did about 80 miles of stop and go cruising yesterday and average dropped to 27~ using about 1/4 tank so i'm quite surprised with how little it uses.
Build Thread
Instagram
ImperiousRex Time Attack BRZ **Evasive Tuned 271whp Greddy Turbo** Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 18 07-24-2014 07:38 PM
ImperiousRex Time Attack BRZ **Evasive Tuned 271whp Greddy Turbo** Evasive Motorsports Forced Induction 21 02-07-2014 11:12 AM
Bon Sleeper BRZ AVO TURBO **Evasive Tuned** Evasive Motorsports BRZ Photos, Videos, Wallpapers, Gallery Forum 37 12-27-2013 02:29 AM
Greddy Turbo kit tuned by R/T Tuning (320hp) R/T Tuning Forced Induction 37 12-14-2013 04:16 PM
Bon Sleeper BRZ AVO TURBO GRAPH **Evasive Tuned** Evasive Motorsports Forced Induction 42 09-26-2013 09:26 PM
