Old 12-15-2013, 05:09 PM   #29
jamesm
Originally Posted by Kinaa View Post
Well that was my First pull after flashing my ECU with that tune , already sent the csv file to Shiv
btw what do you think the AFR range should be with my setup ?
your iam is zero because you're trying to run 29 degrees of timing under boost. so you essentially took an na tune and are driving a supercharged car with it? please don't do that. for the children.
Old 12-15-2013, 05:33 PM   #30
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
His IAM is at zero because IAM doesn't log on non USDM cars yet. That is not to say that he isn't running to much advance in his boost application though.
Shiv@Openflash is offline   Reply With Quote
Old 12-15-2013, 05:57 PM   #31
jamesm
ahh yes... forgot about that one. it probably would be anyway, though fwiw. or at least real close to it. you can see it pulling a bunch of timing in all the wot runs.
Old 12-15-2013, 05:58 PM   #32
JT86
Any plans to have a Valet mode map that can reduce the rev limiter and limit power. Plan on dropping car at a body shop and would not like those delinquents to be able to abuse it.
JT86 is offline   Reply With Quote
Old 12-15-2013, 06:48 PM   #33
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
When my automatic is in gear and at a stop, the RPM sits at about 700. Which table would I change to increase the idle to 900?
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 12-15-2013, 10:46 PM   #34
s2d4
s2d4's Avatar
Idle target Maps. Change all the instance of 700 to what you want would be a starting point.
Old 12-15-2013, 10:52 PM   #35
s2d4
s2d4's Avatar
I wonder if changing the rev limit to ~1500 would be enough.
There is an unk speed limit map but not sure if that is actually the speed limit we are thinking of...
Old 12-16-2013, 02:01 AM   #36
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
hey shiv i keep gettin error code 0x68 while communicating with device. trying to put 3 maps on the OFT.. its manager 1.04 , never saw this before
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 12-16-2013, 02:03 AM   #37
Shiv@Openflash
Drives: 2013 FRS
You are still only able to load 2 modified files into the OFT at this time. Despite this latest OF Manager software version which shows 5 map banks. The OFT firmware is about to be updated which will allow you to load 5. But that is still a few days away. If you try to load more than 2, you will get that error code.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Grip Ronin (12-16-2013)
Old 12-16-2013, 09:07 AM   #38
Malt
Drives: 2015 WRX
Shiv, the changes you made to the cranking tables are insufficient for temps below 30. 40+ cranking attempts this morning and I'm still stuck at work with no way to adjust the tables since I don't have a laptop and my computer is at home. Looks like if I can actually get this thing started I'm going back to the changes I made... at least they would get me started in 5 or less attempts.
Malt is offline   Reply With Quote
Old 12-16-2013, 10:06 AM   #39
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
I know this doesn't help Malt with his issue, but for everyone who hasn't gotten stuck somewhere might I suggest always keeping two tunes on your oft to avoid his situation. One you know will work safely and another that you haven't fully tested yet.
FrsDuke is offline   Reply With Quote
Old 12-16-2013, 10:19 AM   #40
Malt
Drives: 2015 WRX
This will largely be fixed once more than two maps can be loaded onto the OFT at the same time. I have the E85 map I'm using plus a normal Stage 2 map loaded just incase I have to take a trip somewhere and there is no E85 available. I knew I wasn't going anywhere yesterday or this morning other than work and then home so I guess I could of put my previously known working E85 map on there instead of the normal stage 2. With the ability to load 5 maps I could of loaded the new beta map and tested it when it was cold without fear of being stranded. Regardless I got it cranked finally after 45 minutes of trying.
Here's a data log of a couple attempts to get cranked for those that are curious. Not sure how helpful they will be. http://www.datazap.me/u/malt/cold-st...-12-16-13?1-11
Disclosure, I make no claims as my abilities of tuning a car or even adjusting tables in these maps. These changes were the result of discussions with much more knowledgeable people than me. They were not my idea so don't give me credit.
For those of you that are potentially having cold start issues like me, here is a copy of the tables I've used with success. It starts on the first try 80% of the time and on the 2nd attempt 99% of the time. These changes have worked for me for temps down to 21 degrees. Below that I have no clue and make no claims to its ability to work.
Essentially its the tables used on the 1.40 E85 maps but with the 68 degree columns multiplied by 1.2, the 50 degree columns multiplied by 1.25 and everything below that multiplied by 1.3
The Fuel IPW Compensation A tables are zero'd out.
The Following 5 Users Say Thank You to Malt For This Useful Post:
fstlane (10-15-2016), phrosty (05-23-2015), Terrapin77 (01-05-2014), Trettiosjuan (03-03-2015), tskaohu (01-14-2016)
Old 12-16-2013, 11:01 AM   #41
FrsDuke
Fanboy
FrsDuke's Avatar
Glad you got it fired up. 5 tune capacity will be extremely helpful indeed.
Old 12-16-2013, 11:05 AM   #42
Malt
Drives: 2015 WRX
I'm still not sure what the issue is with cold starting and shiv's maps and why my car needs so much more fuel than his to crank. Could be I've got more ethanol in my tank than he does? During the process of trying to adjust my IPW tables I received a link to an article about flex fuel vehicles and how their injectors have heated tips and their intakes have heating elements to help alleviate the cold starting issues.
I've considered adding a gallon of 93 to the tank before I fill up next time based on some of the results I've seen with some peoples LTFT's and cold starting but I should probably test the amount of ethanol before I actually go through with this. Its not that I'm concerned with my LTFT's but the cold starting issues are annoying to say the least.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-14-2014 12:14 AM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 11:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
