#15 |
Drives: 86
Dear @shiv@vishnu
Any plans on releasing support files for ZA1J___K (Gulf AT) soon. Thank you for your support
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#16 |
Drives: BRZ (HKS Superchager)
Here is the 3rd gear pull with the new released rom
http://datazap.me/u/larbikinaa/za1ja1o-3rd-gear-pull?1 |
#17 | |
| The Following User Says Thank You to jamesm For This Useful Post: | s2d4 (12-15-2013) |
#18 |
#19 | |
btw, are you sure you want to run NA tunes on that HKS SC setup? AFR of 15.27 on WOT looks pretty scary. |
#20 | |
btw what do you think the AFR range should be with my setup ? |
#21 |
#22 |
not really , just trying to get a base map that i can start working with , will be adjusting the tune on a Dyno this week.
Btw i dont think the high AFR is caused my the OFT tune , i had made few pulls before with the ECU running Stock , and it seems i'm getting always the same AFR results , check the links below http://datazap.me/u/larbikinaa/brz-p...ger-2-test?1-9 http://datazap.me/u/larbikinaa/brz-p...arger-pull?1-9 i think that's due to the Supercharger , anyway i'll be waiting for Shiv to have a look on it , and if not save to run with that , I will just swith back to the Stock rom |
#23 | |
That is what happens when you don't run a dedicated tune for your setup. There is no OTS tune for the HKS SC, I remember asking you how you were going to get your setup tuned but you never answered. If you didn't go the e-tuning route since you are in china, I am not sure why shiv needs to give you a HKS SC tune. |
#24 | |
I wish I could go for E tuning but as Shiv said , it seems almost impossible as they don't have car with HKS/SC and it needs to be done on a Dyno |
#25 | |
The only thing is that isn't a base tune for your SC kit, it is a stage 1 or 2 tune for NA cars. Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only. Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only. |
#26 | |
but as i said wanted to try the Stage 2 map , which really makes a hug increase in power , i could feel the peak torque starts pulling at 4k RPM but i guess it not safe running my car with that tune |
#27 | |
| The Following User Says Thank You to s2d4 For This Useful Post: | Kinaa (12-15-2013) |
#28 |
Long Distance Driver
Nice to see the update. Thanks guys!
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet E85 (and gasoline) Maps now available | Shiv@Openflash | Software Tuning | 401 | 08-14-2014 12:14 AM |
| OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my | Shiv@Openflash | Software Tuning | 122 | 12-14-2013 11:17 PM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
