Old 08-23-2013, 03:14 PM   #29
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by sw20kosh View Post
Like I said, if you want to diagnose this problem you are going to have to remove the boost controller from the equation. Connect boost or manifold source directly to wastegate. See if there is still creeping going on.
x2
ive never had this problem with my kit
Old 08-23-2013, 04:06 PM   #30
Djen
Drives: GT86
I see ... thanks guys ill try connect vaccum directly to the wastgate lets see what happen.
Djen is offline   Reply With Quote
Old 08-24-2013, 05:39 AM   #31
Djen
Drives: GT86
well... my car throwing CEL+TRC Lights keep me wondering plus boost creep etc I was thinking what the hell this catch can hose hanging over there. the mechanic keept the right hose zip tie at struce tower it was not caped or anything its just keept open to atmosphere.. do you think this is the source problem of CEL boost creep aren't this doin vacuum leak etc?
Old 08-24-2013, 08:11 AM   #32
Djen
Drives: GT86
any support?
Old 08-24-2013, 08:48 AM   #33
Dipstik-sportech
Dipstik-sportech's Avatar
Can't see that causing boost creep that's just crank pressure. It's odd that he has the one side just open like that, most remove the pcv and put that hose in its place.
Old 08-24-2013, 08:49 AM   #34
Alhammadi
Drives: 2013 Toyota FT86
http://www.cusco.co.jp/en/manual/oil...lation_gu.html
check if this is gonna help
Alhammadi is offline   Reply With Quote
Old 08-24-2013, 08:59 AM   #35
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
What CEL code
Sent while popping Mollys
Old 08-24-2013, 09:08 AM   #36
mad_sb
Drives: 2013 Asphalt FR-S
solutions for my issues i'll be much pleased..
Port the hotside / dump port. Make sure you don't have any restrictions in the exhaust where the dump port rejoins the main exhaust or switch to an open dump.
Creep usually has nothing to do with the boost controller (though i have seen the ball stick in a few cheap mbc's), but rather the ability of exhaust gas to bypass the turbine at higher flow rates.
Stiffer spring will only make it worse.
Old 08-24-2013, 09:33 AM   #37
Djen
Drives: GT86
Originally Posted by whitefrs View Post
What CEL code
P0441 and C1201 those poped after leaving gas staion popd after 6-8min while cruising home
Old 08-24-2013, 09:36 AM   #38
Djen
Drives: GT86
hmm ill keep it like that but how can i connect it to pcv there is one goin from intake to down near firewall
Old 08-24-2013, 09:41 AM   #39
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by Alhammadi View Post
Their instructions are incorrect, please don't follow them.
Correct installation of a catch can:
http://www.ft86club.com/forums/showthread.php?p=654722
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-24-2013, 09:45 AM   #40
Djen
Drives: GT86
arlgith sounds good they connect the other hose to intake pcv what about the one down there at frewall can i keep it open? or should i cap it?
Old 08-24-2013, 09:48 AM   #41
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
No side is to stay open
http://www.ft86club.com/forums/showthread.php?t=21079
Old 08-24-2013, 09:52 AM   #42
Djen
Drives: GT86
so i cap it with anything like plastic scrow stuff like that?
The Jet. Boost build. jet86 Member's Car Journals 310 10-06-2015 10:41 AM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
E85+boost subatoy Forced Induction 5 11-06-2012 11:55 AM
any way to reduce or eliminate "idle creep"? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 8 07-03-2012 02:00 PM
AE86 w/F22 + Boost Dragonitti FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 01-09-2011 01:06 AM
