Old 08-23-2013, 02:12 AM   #1
Djen
Drives: GT86
Thumbs down Boost creep
greeting.. boost rise when set to10psi the problem now is boost hold all the way. when RPM Climb around 5000+all the way redline boost creeps higher and higher around 12-13. anything should be warry about it? i just cant keep goin seeing creep like that for safety to engine i pull my foot right the way!!
solutions for my issues i'll be much pleased..
Djen is offline   Reply With Quote
Old 08-23-2013, 02:36 AM   #2
sw20kosh
Drives: 2013 Black FR-S
What turbo kit do you have?
A little bit of creep should be tolerable as long as your data logs look clean of knock.
Usually this happens when your wastegate is insufficient at venting the amount of exhaust gas you are throwing at the turbo.
Also, if you have one, check your boost controller and all the lines that go to and from your boost controller and wastegate for leaks.
The Following User Says Thank You to sw20kosh For This Useful Post:
mad_sb (08-24-2013)
Old 08-23-2013, 02:41 AM   #3
Djen
Drives: GT86
FBM kit and i don't think there is leak. and yes the wasetgate the upper banjo keept open. don't you think I need stiffer wasgate pressure spring? because installed a 6-7psi spring in ther. and yes at WOT the data looks clean I have some knock while crusing on low throttle open..
Old 08-23-2013, 02:48 AM   #4
Dipstik-sportech
Dipstik-sportech's Avatar
What kind of boost controller are u running? Is the wastegate recirculated or open to atmosphere?
Old 08-23-2013, 02:51 AM   #5
Djen
Drives: GT86
FBM manual controller and yes its recirculated back to the EX.
Old 08-23-2013, 02:52 AM   #6
Djen
Drives: GT86
im using regualer vacuum tees to connect hoses that used for water/air metal one should effect? and plastic zip ties
Old 08-23-2013, 11:54 AM   #7
sw20kosh
If you know what you are doing, disconnect the boost controller and go back to just using the wastegate. This will diagnose the problem as:
1. Boost controller malfunction
Or
2. Wastegate malfunction or leak in the boost refrence hoses
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
charged86 (08-23-2013), SloS14 (08-23-2013)
Old 08-23-2013, 11:59 AM   #8
Djen
Drives: GT86
Or
hmm this kinda take times but if I disconnect the boost controller and put it directly how can I boost for 10psi? my wastgate pressure spring only 7psi I think im goin to disconnect the boost controller and re connect them agine with hoses goin to wasgate and see if this dose change
Old 08-23-2013, 12:06 PM   #9
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
What style of Vaccuum line? Cheap "silicone" rubber tends to swell and "drop" pressure. But not usually till higher boost.
Keep the Vaccum lines as short as possible. Avoid "T's" that reduce inside diameter or are a restriction.
I usually plumb the turbo compressor housing direct to wastegate.
If it still does it....
Then either the wastegate has insufficient flow, or if the turbine section is restrictive, the timing could be too low (creates excess heat energy, has greater affect on small housings).
But I like boost creep, 2-3 pounds is very nice
Toma is offline   Reply With Quote
Old 08-23-2013, 12:07 PM   #10
Djen
Drives: GT86
the vacuum start from the intake Manifold Tees not clamped or zip tie just do you think this the cuses leaks? on 10psi?
Old 08-23-2013, 12:08 PM   #11
Djen
Drives: GT86
the mechanic used Brass Tees
Old 08-23-2013, 12:11 PM   #12
Djen
Drives: GT86
what can I do im using two of T brass tees that's not good at all or?
Old 08-23-2013, 12:13 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have never ever seen boost creep on my FBM kit, only boost loss in the upper RPM range. I would say there might be an exhaust leak at your wastegate.
Old 08-23-2013, 12:15 PM   #14
Djen
Drives: GT86
hmm ill snap shot some and post the way im connecting the tees alright
The Jet. Boost build. jet86 Member's Car Journals 310 10-06-2015 10:41 AM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
E85+boost subatoy Forced Induction 5 11-06-2012 11:55 AM
any way to reduce or eliminate "idle creep"? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 8 07-03-2012 02:00 PM
AE86 w/F22 + Boost Dragonitti FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 01-09-2011 01:06 AM
