Old 11-08-2012, 12:59 PM   #57
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by wu_dot_com View Post
yikes... let me go check on mine to see if i can see any oil spots. perhaps you have a bad seal or something, it could be an isolated incident. since this is the only leaking incident i've seen this far.
since you've put back the OEM pulley, have you notice any more leaking?
Sorry I missed this somehow. I have been noticing the smell, but not nearly as often. I'm gonna talk to Toyota soon and have them look at it to 'find the leak.'
good luck.
Old 11-08-2012, 07:14 PM   #58
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Esoteric View Post
Wise advice
You must remove the crank bolt to do the swap. Perrin informs you that you might need to replace this but the layperson won't truly know when to.
My advice would be: better safe then sorry, especially for the folks who google this a few years down the road with even more miles.
Hardware stretches and professionals don't risk this type of failure.
Since you can't measure the bolt before it was installed at the factory (Its called bolt stretch), you play a guessing game. You may want to buy a new bolt for this job.
Also, the manual trans is an easy job, the auto trans cars require the factory or a similar tool solution to lock the flex-plate for install.
On my old Celica it was recommended to upgrade the flywheel bolts when swapping in a lighter unit. Would you recommend the same with the 86/FRS? Does anyone know if ARP make flywheel bolts for the FA20?
1974 TA22 Celica
2013 86 GT
Old 02-09-2013, 02:35 AM   #59
Racecomp Engineering
Originally Posted by Draco-REX View Post
This car is screaming for lightweight flywheel/pulley/CF driveshaft.
It's nice to know that the lightweight pulley/flywheel combo isn't causing misfire CELs.
WORD ! I am looking forward to doing the flywheel, CF driveshaft............
...along with my 4.55 final drive !
TRD has one that is 12lbs ( flywheel weight).
So thats 10lbs savings from flywheel and 10 lbs savings from driveshaft. 20 lbs rotational HAS GOT to make more power ! I know doing the 4.55 gears FELT LIKE I added at least 15whp.
Any updates from anyone else who has done the flywheel in the last few months? Any dyno results?
Myles
Mr. (09-04-2013), TouchMyHonda (04-13-2013)
Old 02-09-2013, 02:41 AM   #60
Imagine a LFA type rev at a stop light ?
[ame="http://www.youtube.com/watch?v=EWMpDqN74ng"]LFA blipping & take off - YouTube[/ame]
Man a nice flat plane crank shaft would be awesome !
( dream a little dream )
Myles
Old 02-09-2013, 02:42 AM   #61
000 Racing
000 Racing's Avatar
Drives: 2012 86GTS Race Car #86
I recently found the GFB - Go Fast Bits who have a kit of crank pulley, water pump and alternator pulleys in black aircraft alloy billet... nice work. About to fir it to the car but all up saves massive weight... if anyone wants specifics I will post them..
000 Racing is offline   Reply With Quote
Old 03-18-2013, 04:20 AM   #62
evilconcarne999
My LFA
evilconcarne999's Avatar
Drives: No Boost
Myles
I have the crank pulley alternator and waterpump pulleys, a carbon driveshaft and the ACT lightweight street clutch and flywheel combo, flywheel is 10.5 lbs so another about 10lbs shaved off my car plus faster reving and hopefully this is the solution to the problem thats causing the crap performance when I launch my car. I am also going to be moving to a upgraded final drive plus headers to hopefully get a good portion of the torque dip removed. I plan on dynoing my car one of these days to see how all the lightweight parts have affected my car.
evilconcarne999 is offline   Reply With Quote
Old 03-18-2013, 08:45 AM   #63
Captain Insano
Sounds like that would be awesome combo. Post back when you have it all finished up!
when the engine bay is hot, the engine idle will fluctuate immediate after throttle let off. for example, if i am driving at constant 5K RPM and let off the throttle and step on the clutch, the engine RPM will quickly drop to slightly below 600, then bounce back to 1200, then settle at 800, before reaching a steady state of 600. also. when the drive train is hot (hot day condition, long drive condition, or harsh acceleration) it seems to generate much more engine vibration at some RPM. for my setup, the heighten vibration RPM range are 600-1000 RPM in natural, 2800-3500 RPM under load. Turning on the AC also produces more vibration at all RPM range and load condition.
I thought this was pretty normal with a light weight flywheel. I had a LWF on my STi and it would hunt a little bit and drop to lower than normal RPM when you let off throttle abrubtly and clutched.
Captain Insano is offline   Reply With Quote
Old 03-18-2013, 11:25 AM   #64
evilconcarne999
My LFA
Drives: No Boost
Yeah once I get it all set in ill post some dyno pics and my impressions of performance gain and daily driving. Either on here or my car build page. Im also going to be hitting up a fresh retune with the newer parts once I purchase the flexfuel tune and fuel lines. Be interesting to see what all the parts pluss E85 does for my car.
The Following User Says Thank You to evilconcarne999 For This Useful Post:
Old 04-13-2013, 07:04 PM   #65
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Do you have all the parts already? Also can you post a link back in this thread so we can all keep track of your progress?
Thanks!
TouchMyHonda is offline   Reply With Quote
Old 04-13-2013, 09:54 PM   #66
evilconcarne999
My LFA
Drives: No Boost
Thanks!
Only thing i havent been able to purchase is the flexfuel tune and final drive, final drive is proably my next modification, flexfuel im waiting on for now.
WSIR 1:46.023 (Need Better Tires)
My Car Build: 171.9WHP/137WTQ (Mustang Dyno)
http://www.ft86club.com/forums/showthread.php?t=21824
My For Sale Aftermarket and OEM parts
http://www.ft86club.com/forums/showt...484#post998484
Old 06-17-2013, 09:55 AM   #67
mixcorp
Drives: brz
Plan on getting LWF, just dont know whether ill get the STREETLITE or the PROLITE. Any CELs on these ? read somewhere about the STIs CEL on having a flywheel below 12lbs. Though not the same car, just wondering if someone had CEL issues on prolite flywheels already. Getting GFB also
mixcorp is offline   Reply With Quote
Old 06-18-2013, 02:35 PM   #68
evilconcarne999
My LFA
Drives: No Boost
Nope I can say that I never had a CEL due to any lightweight parts and im running an extremely light drivetrain thats including a lightweight flywheel. I also had a tune pre headers and after installing my headers a while back I still have not gotten a CEL so I dont see any issues arrising from lighter parts but everyones car reacts differently just my personal experience.
Old 06-18-2013, 02:42 PM   #69
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I just placed an order for a clutch with a Prolite disc. (And a CF driveshaft) It may be a few weeks before I have it on, however. But there's someone here running one on the street and he said once he got used to it, he isn't having any issues.
Old 06-23-2013, 09:01 PM   #70
KpAtch3s
Drives: 2013 Scion F-RS
Is the carbon drive shaft stronger as well? I assume it would be. Curious how well it would handle additional power. My goal is to eventually sitting at 400-450whp
KpAtch3s is offline   Reply With Quote
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 02:35 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
