Old 01-29-2018, 12:39 PM   #15
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by speedyspaghetti View Post
The shifter vibrates as well.
Like Tcoat said many things could cause it. Sometime my steering wheel vibrates, sometimes my shifter, sometimes both. Usually it means I need to rotate the tires, my alignment is off, or a wheel is not balanced.
I would start there, especially if it seems to get worse the faster you go indicating its rotational.
Old 01-29-2018, 12:39 PM   #16
stevesnj
stevesnj's Avatar
That was one funny movie ............
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
humfrz (01-29-2018)
Old 01-29-2018, 01:48 PM   #17
speedyspaghetti
speedyspaghetti's Avatar
Drives: 2016 FR-S
There are no other vibrations in the car? Steering wheel, shifter, etc?
Unrelated note - is 86Drive only in the East Bay? Or do you guys do South Bay and Peninsula stuff too?
Daily: 2016 FR-S
Weekend: 2002 Boxster S
Retired: 2007 Mazdaspeed3, 2000 M5
speedyspaghetti is offline   Reply With Quote
Old 01-29-2018, 01:56 PM   #18
finch1750
finch1750's Avatar
86Drive does drives everywhere (Mines/Mt Ham and La Honda/Skyline are some of our favorites). But the drives mostly happen in the summer.
But 86Drive is just our driving group, Norcal86 hosts meets year round. If you want to hit up a meet in those areas check out the Southbay bi-weekly meet or Peninsula bi-weekly meet threads in the norcal subforum.
Old 01-29-2018, 03:28 PM   #19
Speedy, the accelerator isn't mechanically connected to anything but the floor board. You can think of it as a foot-operated volume control.
Something else is vibrating and you just happen to feel it there.
speedyspaghetti (01-29-2018)
Old 01-29-2018, 04:41 PM   #20
speedyspaghetti
Drives: 2016 FR-S
Is the throttle spring-assisted like the clutch? Could this be the issue?
Daily: 2016 FR-S
Old 01-29-2018, 05:17 PM   #21
No. There's a spring but it's a really simple return spring. Think of the trigger on a cordless drill.
Old 01-29-2018, 08:24 PM   #22
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Electronic Throttle Control (Drive By Wire) explained:
[ame="https://www.youtube.com/watch?v=Pgln9L5Y7sQ"]Drive By Wire - Electronic Throttle Control - Explained - YouTube[/ame]
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Old 01-29-2018, 09:34 PM   #23
speedyspaghetti
Drives: 2016 FR-S
I just got the alignment done recently, but I remember that before it started happening, I fishtailed a little bit on one of those first rainy days with my shit tires from the PO. Could potentially be a flat spot on the rears? I'll try rotating the tires over the weekend to see if that does anything. Pressure is at 38 all around, which is a bit high, so I might also drop it down to 35 and see if that does anything.
Daily: 2016 FR-S
The Following User Says Thank You to speedyspaghetti For This Useful Post:
Tcoat (01-30-2018)
Old 01-29-2018, 10:05 PM   #24
That would to be expected.
That would be a good idea.
speedyspaghetti (01-30-2018)
Old 01-30-2018, 12:10 PM   #25
stevesnj
stevesnj's Avatar
Balance the tires
Buzzing/vibrating gear stick paulca Issues | Warranty | Recalls / TSB 49 10-12-2017 12:47 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 11:56 PM
Rear License plate vibrating primalT Cosmetic Modification (Interior/Exterior/Lighting) 11 05-03-2014 02:20 AM
Exhaust is vibrating a bit.. pgeist Engine, Exhaust, Transmission 3 07-09-2013 03:00 AM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 01:11 PM
