Old 12-26-2015, 08:00 PM   #29
Originally Posted by Dream20b View Post
yeah we'll see. I'll have to get it towed again because I cannot do electrical work, lol.
Doh!
Dream20b (12-26-2015)
Old 12-27-2015, 09:07 PM   #30
Dream20b
Y u do dis?
this is a dumb question but which fuse goes to the maf sensor? What's it labled?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 12-27-2015, 09:31 PM   #31
It's not fused by itself but the bus to which it receives its power is fused by the 15 Amp EFI(CTRL) fuse.
If the red wire is cut and was shorted to ground, yes, that fuse will have blown.
Dream20b (12-28-2015)
Old 12-28-2015, 03:41 PM   #32
Dream20b
Y u do dis?
Fuse was indeed blown, Also, Fixed. Swapped fuse, wrapped wires in electrical tape, will update when new belt purchased.
Dat Hot Lava Doe
Old 12-29-2015, 01:18 AM   #33
Great catch!
Dream20b (12-30-2015)
Old 12-30-2015, 08:49 PM   #34
Dream20b
Y u do dis?
Buying belt tomorrow.
Dat Hot Lava Doe
Old 12-30-2015, 09:35 PM   #35
whataboutbob
AutoX-10/10ths every run
I ended up using a piece of smaller diameter coolant hose to create a sheath for the MAF sensor cable harness to protect it from shredding belts on mine. Cut it down the center lengthwise and use a large zip tie at either end to anchor it to something fixed.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Dream20b (12-31-2015)
Old 12-31-2015, 09:52 AM   #36
Dream20b
Y u do dis?
belt has been purchased, And I found that the original anchor was broken so i bought one of those too
Dat Hot Lava Doe
Old 12-31-2015, 09:14 PM   #37
Dream20b
Y u do dis?
Update...
Car flickers lights when attempting to start, doesn't start, but cranks. Lights solid in on position.
Dat Hot Lava Doe
Old 12-31-2015, 09:30 PM   #38
steve99
Drives: FT86
Update...
With all the messing arround your battery might be low, maybe put the charger on it for a couple of hours and see what happens.
If you have a voltmeter get someone to keep an eye on battery volts when you crank it should be able to maintain arroind 12v if its dipping to 10 or something then its low or stuffed.
Also rescan for error codes, car wont usually start if maf sensor damaged or not connected same with map sensor.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Dream20b (12-31-2015), Ultramaroon (01-01-2016)
Old 01-01-2016, 07:02 PM   #39
Dream20b
Y u do dis?
Car runs and drives after new battery. Charging did nothing
Dat Hot Lava Doe
The Following 2 Users Say Thank You to Dream20b For This Useful Post:
steve99 (01-01-2016), Ultramaroon (01-01-2016)
installing sensor/adapter for oil temp and pressure - how? pcuerpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 06-29-2018 07:40 AM
Where BRZ ATM pressure sensor?? silviahrc Engine, Exhaust, Transmission 3 12-12-2015 04:28 AM
Beta Testers Wanted- Fuel Pressure Sensor GSpeed Tracking / Autocross / HPDE / Drifting 5 08-16-2015 05:03 PM
Oil pressure and Oil Temp sensor - where did you mount them and how philooo Engine, Exhaust, Transmission 11 05-29-2015 03:41 AM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-28-2013 12:38 AM
