Old 05-01-2019, 11:51 PM   #1
Phoenix_gts86
Phoenix_gts86's Avatar
Drives: 2013 MY14 Toyota gts86 Turbo
AEM Tru Boost Vacuum Line
Hey I have finished installing my Aem Tru Boost gauge into my Turbocharged 2013 Gts86, everything is connected, if it wasn’t the gauge would be showing Error.
I have tapped the vacuum line from the gauge into the brake booster and the gauge is reading double the amount of psi the car is running, my oft reads the correct amount and the gauge is reading double that amount. Where the oftv2 will read about 9/10, the gauge will read -18/-19
Where about can I tap the vacuum line from the boost gauge?I’ve attached the bov vacuum line into the 4 piece connector with the boost gauge.
Thanks a bunch!
Phoenix_gts86 is offline   Reply With Quote
Old 05-02-2019, 07:53 AM   #2
tomm.brz
Drives: brz 2017 hksv2
with oft you mean "boost" value?
boost value is a relative pressure measurement, on brake boost line is manifold absolute pressure, ergo boost + atmospheric pressure
Old 05-02-2019, 09:07 AM   #3
Fred E
Drives: WRB BRZ
Thanks a bunch!
This might be because the OFT is reading PSI when in vacuum, while the gauge is reading inHg. The conversion factor from PSI to inHg is 2.036 (i.e. inHg = PSI x 2.036). When you go into positive pressure, the gauge should switch to PSI automatically, and then back to inHg when in vacuum.
Edit: main point being that there is no concern with your routing and you can go enjoy the boost.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
tomm.brz (05-02-2019)
Old 05-02-2019, 09:27 AM   #4
Phoenix_gts86
Yeah with oft I meant boost value, I just would have thought it should be reading the same as the oft but then again the oft doesn’t have a vacuum line being tapped into the brake booster line
Old 05-02-2019, 09:30 AM   #5
Phoenix_gts86
Oh okay that’s something to learn from, as said in previous reply to Tom.brz “Yeah with oft I meant boost value, I just would have thought it should be reading the same as the oft but then again the oft doesn’t have a vacuum line being tapped into the brake booster line”
Looks weird when it’s -18/-19 then goes positive when hitting boost while the oft displays -10 and reaches positive boost “naturally”
Where is the safest spot to T a vacuum line? Wil Engine, Exhaust, Transmission 9 07-18-2017 10:58 AM
Under manifold vacuum line for dedicated BOV source? xkalelx Forced Induction 4 01-20-2016 06:09 PM
Turbo vacuum line setup g0odspeed Forced Induction 13 12-13-2015 01:40 AM
Vacuum hose for boost controller ChrisD Forced Induction 6 08-13-2015 05:24 PM
-30hg/in vacuum and only 1 psi boost lx93 Forced Induction 6 06-02-2015 08:31 PM
