Old 01-12-2016, 06:55 PM   #1
Jahris
Drives: 2013 Scion FRS
How many catalytic converters are on this car?
I live in Ca, smog restrictions! How can I get the most flow in the exhaust with a uel header without getting cel's and still pass smog? Thanks for your time.
Jahris is offline   Reply With Quote
Old 01-12-2016, 06:57 PM   #2
You cannot pass smog with ANY aftermarket header.
Old 01-12-2016, 06:57 PM   #3
Shoekabob
Shoekabob's Avatar
Drives: 2013 Ultramarine FR-S
There are two cats, one in the header and one in the front pipe. I'm not sure if you'd be able to pass CA emissions with either removed, but I don't know much about the requirements.
Shoekabob is offline   Reply With Quote
Old 01-12-2016, 07:00 PM   #4
ryoma
ryoma's Avatar
swapping back your stock header just for smog checks is probably your best bet. if you do some stupid stuff on the street and get pulled over, the cop could also want to check out your car and send you to the state ref. you would need to swap back to stock for that as well
Old 01-12-2016, 07:00 PM   #5
Jahris
Will the catless header throw cel's?
Old 01-12-2016, 07:03 PM   #6
Lord09
Drives: 2015 BRZ
Yes. You'll need some type of tune to turn it off.
Lord09 is offline   Reply With Quote
Old 01-12-2016, 07:13 PM   #7
Jahris
What type of tune are speaking of?
Old 01-12-2016, 07:43 PM   #8
_gt86_user
Inactive
Drives: .
You just need a simple Off The Shelf (OTS) tune, your best bet is the Openflash tablet. You may go ecutek if you choose just depends how much you want to spend and what your future goals are. Or try your luck with a CEL (O2) sensor spacer and no tune up to you.
_gt86_user is offline   Reply With Quote
Old 01-12-2016, 07:55 PM   #9
Jahris
Afe has catted header, will cel's show then? I have the obd2 scanner tool to turn off cel's. Is that the same?
Old 01-12-2016, 08:24 PM   #10
Lonewolf
Lonewolf's Avatar
Drives: Moped
Running catless in California is a lot like having unprotected sex with strippers. Sure, you might escape the bad stuff for a while, but eventually you get syphilis...er, I mean ticketed
Old 01-12-2016, 08:38 PM   #11
ryoma
ryoma's Avatar
not to mention those rolling smog checks... they have calmed down lately though.
Old 01-12-2016, 09:13 PM   #12
Bykov
Drives: 2014 Monogram FR-S Whiteout
This ^
Even if you buy a catted header, it will still fail smog without a CARB sticker since you are in California. The only thing you can do for your exhaust legally is a cat-back and an OP (but even that is debatable because the law states modifications can be made only after the last cat however the OP does not replace any emissions equipment). Luckily it's not worth arguing because it won't do anything for you without a full exhaust.
Bykov is offline   Reply With Quote
Old 01-12-2016, 10:37 PM   #13
steve99
This is still not strictly legal
But get an OFT
Run the E85 EL header tune on a completly stock car
No cel problems
Car is completly stock hardware wise
If you do get pulled for a complete inspection jist fill tank with petrol again and flash back stock tune takes 5 munites no tools ect
E85 tune on stock car worth about 20hp just e85 fuel and a tune.
Old 01-12-2016, 11:21 PM   #14
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Just get the header you want and switch it back to stock before smog. As far as CEL's you can get an O2 spacer which isn't a guaranteed fix or just go for a tune for a definite fix. A tune will not make you pass smog however
wise345 is offline   Reply With Quote
Questions about spacers/converters. HachiRo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 07-28-2015 06:42 PM
bolt converters Mr. Want-To-Buy Requests 0 08-21-2014 10:33 PM
Catalytic converters and E85 unsurety Engine, Exhaust, Transmission 14 06-19-2014 09:02 PM
Newb question regarding aftermarket catalytic converters BigFatFlip Engine, Exhaust, Transmission 9 03-24-2014 11:01 AM
Performamce Catalytic Converters. LBC Por Siempre Forced Induction 3 01-14-2014 05:43 PM
