Drives: 2013 Scion FRS
How many catalytic converters are on this car?
I live in Ca, smog restrictions! How can I get the most flow in the exhaust with a uel header without getting cel's and still pass smog? Thanks for your time.
#2 |
You cannot pass smog with ANY aftermarket header.
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | Dream20b (01-13-2016), Packofcrows (01-23-2016), RobertPaulson (01-14-2016), wparsons (01-12-2016), _gt86_user (01-12-2016) |
#3 |
Drives: 2013 Ultramarine FR-S
There are two cats, one in the header and one in the front pipe. I'm not sure if you'd be able to pass CA emissions with either removed, but I don't know much about the requirements.
#4 |
swapping back your stock header just for smog checks is probably your best bet. if you do some stupid stuff on the street and get pulled over, the cop could also want to check out your car and send you to the state ref. you would need to swap back to stock for that as well
#5 |
#6 |
Drives: 2015 BRZ
#7 |
#8 |
Inactive
Drives: .
You just need a simple Off The Shelf (OTS) tune, your best bet is the Openflash tablet. You may go ecutek if you choose just depends how much you want to spend and what your future goals are. Or try your luck with a CEL (O2) sensor spacer and no tune up to you.
#9 | |
#10 |
Drives: Moped
Running catless in California is a lot like having unprotected sex with strippers. Sure, you might escape the bad stuff for a while, but eventually you get syphilis...er, I mean ticketed
| The Following 8 Users Say Thank You to Lonewolf For This Useful Post: | continuecrushing (01-14-2016), Cop (01-13-2016), go_a_way1 (01-13-2016), KR-S (01-13-2016), Packofcrows (01-23-2016), sato (11-27-2021), Teseo (01-12-2016), wparsons (01-12-2016) |
#11 |
not to mention those rolling smog checks... they have calmed down lately though.
#12 |
Drives: 2014 Monogram FR-S Whiteout
This ^ Even if you buy a catted header, it will still fail smog without a CARB sticker since you are in California. The only thing you can do for your exhaust legally is a cat-back and an OP (but even that is debatable because the law states modifications can be made only after the last cat however the OP does not replace any emissions equipment). Luckily it's not worth arguing because it won't do anything for you without a full exhaust. |
| The Following User Says Thank You to Bykov For This Useful Post: | wparsons (01-12-2016) |
#13 |
Drives: FT86
This is still not strictly legal
But get an OFT Run the E85 EL header tune on a completly stock car No cel problems Car is completly stock hardware wise If you do get pulled for a complete inspection jist fill tank with petrol again and flash back stock tune takes 5 munites no tools ect E85 tune on stock car worth about 20hp just e85 fuel and a tune. |
#14 |
Slow I am, boost I must..
Drives: Whiteout 2013 FRS
Just get the header you want and switch it back to stock before smog. As far as CEL's you can get an O2 spacer which isn't a guaranteed fix or just go for a tune for a definite fix. A tune will not make you pass smog however
| Questions about spacers/converters. | HachiRo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 07-28-2015 06:42 PM |
| bolt converters | Mr. | Want-To-Buy Requests | 0 | 08-21-2014 10:33 PM |
| Catalytic converters and E85 | unsurety | Engine, Exhaust, Transmission | 14 | 06-19-2014 09:02 PM |
| Newb question regarding aftermarket catalytic converters | BigFatFlip | Engine, Exhaust, Transmission | 9 | 03-24-2014 11:01 AM |
| Performamce Catalytic Converters. | LBC Por Siempre | Forced Induction | 3 | 01-14-2014 05:43 PM |
