sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Newb question regarding aftermarket catalytic converters
Pardon my ignorance, but I'm curious about aftermarket catalytic converters, specifically the ones that have been coming out on headers and over pipes for our cars. I understand that cats generate a lot of heat as part of their function. Naturally, the stock headers and catalytic converters have a lot of heat shielding, which I assume is to keep all the excessive heat away from its surroundings (ie oil pan for the headers, etc). I've noticed that a lot of the aftermarket options don't have any heat shielding at all. I've noticed a handful of folks heat wrap their parts, which I would have thought would be more common, but almost everybody just installs them as-is.
Why is wrapping not as common? Why don't people put any adhesive heat shielding on other components like the oil pan? Do aftermarket exhausts have the heat shielding already build in? |
#2 | |
Proud of BOXER
Drives: Subaru Boxer
The answer to all of your questions can be summed up in two words: BECAUSE. RACECAR.
But seriously I have wondered some of the same things. Free bump!
Señor Member
I have seen plenty of photos of people using adhesive heat sheilding on the oil pan. A large number of people also get their headers ceramic coated to reduce the heat it dumps into the engine bay. People tend to shy away from wrapping headers due to the fire risk they pose and the increased risk of corrosion. Although i have read some people talk of a sealing spray you can use on the wraps that improve that situation.
1974 TA22 Celica
2013 86 GT |
Coffee Snob
Drives: '14 SWP BRZ Limited
Could it be that the wraps contain the heat so well that it leads to speedy deterioration of the exhaust components being wrapped? I've heard of headers cracking due to the heat being contained.
Drives: Pavement MT GR86
I was told the cracking had more to do with wrapping them too tightly and preventing expansion of the metals than holding too much heat.
GR86 MT premium
#6 | |
I believe there is some type of high temperature spray you can spray over over the heat wrap to reduce the fire risk. Do folks just think that the headers and parts of the exhaust just don't get hot enough to need any shielding? |
Drives: 2013 Scion FR-S 6MT
the OE is generally very cautious about heat. not necessarily worried about performance, but risk of fire (ie, parking your car in tall grass, leaves, etc). also heat in the engine bay leads to a higher rate of degradation in rubber components (belts, hoses, wire insulation, etc) and are making cars to last a long time with fewer problems. at least that's their intention. aftermarket companies generally aren't worried about other stuff lasting, so long as their part holds up.
and btw your catalytic converter gets waaay hotter than the manifolds, but the manifolds are right up in your engine bay, hence the heat wrap on headers.
Drives: 2014 Whiteout TRD FR-S 6MT
This is great info, I also hear about people saying the cats don't last long in after market headers/front pipes. If they must be replaced don't header cats also need the same?
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
#10 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I toasted my cat at track into a marshmallow
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
| Newb Brake bed-in (bedding?) question | BigFatFlip | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-16-2016 03:40 AM |
| Quick newb question | Gt86_nick | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-17-2014 07:58 PM |
| Performamce Catalytic Converters. | LBC Por Siempre | Forced Induction | 3 | 01-14-2014 05:43 PM |
| Newb question- springs vs coilovers | wbradley | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 09-12-2012 10:09 AM |
| newb rim question | carbonBLUE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 06-29-2012 01:07 AM |
