Old 12-18-2015, 12:37 AM   #1
RIP.S2000
RIP.S2000's Avatar
Drives: 2015 BRZ Series.Blue, ('00 S2000)
High negative FLKC values on the highway
My motor and tune is stock, but I use the OFT to monitor IAM, FLKC, etc. It's about 50 degrees F tonight, and I'm getting negative FLKC values up to ~1.2 when moderately accelerating on the highway (throttle about half way). My IAM will stay at 0.70 and try to climb back up if I go WOT at high RPMs, but once it gets to ~0.90, negative FLKC kicks it back down.
I'm not sure if the gas I'm using isn't really 93 octane, or if there's something else wrong. I just had the front cover replaced because it was leaking oil, so they had to "re-silicone" it. I'm not sure if it's even related. The oil temps were around 212 F and coolant around 200 F. I wasn't able to log it as the traffic was really hectic, and I was in a hurry.
I'm paranoid, guys. I'd be grateful for any insight.
I'm about to use the stage 2 tune after I put on my headerback exhaust, but I'm afraid to do it if there's anything wrong internally. I don't wanna fight with Subaru.
RIP.S2000 is offline   Reply With Quote
Old 12-18-2015, 02:01 AM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Working as intended.
Old 12-18-2015, 02:29 AM   #3
RIP.S2000
RIP.S2000's Avatar
So there's nothing to worry about?
Old 12-18-2015, 04:28 AM   #4
JB86'd
JB86'd's Avatar
Drives: JAWS
Well you COULD try some different 93 octane near you, but you're fine either way.
When you load the stage 2 tune, load the 93 octane tune, and if it's knocking in high RPM, you can try the 91 octane tune. The only difference is more timing in the upper rpms.
JB86'd is offline   Reply With Quote
Old 12-18-2015, 10:36 PM   #5
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Have you done any modification to the exhaust? Does this show up upon throttle tip in?
Intent > Content
Question About Negative Camber: More Negative Camber == More Grip at Corner? Figo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 03-10-2019 02:08 PM
BRZ Values Apex_BRZ BRZ First-Gen (2012+) — General Topics 20 10-16-2014 05:38 PM
OpenFlash Manager v1.08.3 now available for download (FLKC) Shiv@Openflash Software Tuning 120 06-22-2014 07:34 PM
OpenFlash Tablet: Multi-Gauge Function and FLKC logging Shiv@Openflash Software Tuning 52 05-08-2014 08:30 PM
Safe values? mike_ekim1024 Software Tuning 12 11-05-2013 01:19 PM
