Drives: Argento Scion FR-S
Safe values?
I just installed a rom from my tuner.. and although this isn't the final one since I'll be sending him logs, I'm curious if it's safe to drive the car with this tune. This is after a 20 minute run on freeway and windy roads.
Code:
Min Curr Max AFR: AFR 1.01 14.70 20.44 Advance Multiplier 0.24 0.28 0.70 Knock Correction -4.2 0.00 0.00 Mike
Drives: car
Well the AFR reading is useless. It's at the cruising/idling AFR under "current" and the "Max" is from deceleration fuel cut.
It looks like the knock control system is consistently retarding spark, because your Advance multiplier should have increased up to 1.00 instead of dropping down to .24 and coming back up to .28 . Is it safe to drive the car? If this were a WRX or STi, there's a lot bigger risk of damaging something simply because they are turbo. In the interest of being kind to your engine though, lay off heavy acceleration until you get the updated tune from your vendor. |
| The Following User Says Thank You to arghx7 For This Useful Post: | SkullWorks (10-08-2013) |
Drives: 2013 "AVO Orange" FR-S
It's useful to log knock correction, fuel trim long and short trim, IAM, and, well, quite a few other parameters.
But in general, seeing a knock event of that size along with an IAM around .24 means you are seeing a fair amount of detonation. On crap 91 octane at 8psi of boost, if my IAM comes down to the .7 range I'm generally concerned and take my foot out of it, unless there is no knock events and it's just pulling the timing due to load. |
NASA SpecE30 Racer
What were the max and minimum knock correction learn values? It is much more useful to post up a screen shot of say RPM, AFR, Knock Correction, Knock Correction Learn Value, and Ignition Timing.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
PhoneFlash by EcuTeK
With our tunes we prefer to keep the Advance Multiplier as close to 1.00 as possible in all scenarios. Of course with these cars they do adjust, as these ECU's do seem a lot more sensitive to knock then STI's and WRX engines.
Though the compression is quite a bit higher, nearly 8:1 on an STI and 12:1 on a BRZ/FR-S, is quite a jump. So we do expect to see changes within the range of 0.70-1.00 over weeks/months of driving. But do note this is our method of tuning and not every tuners preference. Though 0.24 may be low by some tuners standards it still has the ability to adjust, as it has not pegged it's lower limit of 0.00. So it really depends on each tuner and how they prefer to tune each vehicle. More information can be helpful in determining what is more likely happening within the tune. Cheers, William Knose |
#6 | |
Now that I'm kind of babying it this week, I miss driving it hard. But soon..
#7 | |
Glad we could have been some help. If you have any more questions, please ask. Cheers, William Knose |
Drives: car
It's hard to know what an engine is going to like on the first shot, especially without the engine in front of you. Your tuner will figure it out with time. While e-tuning is not something I personally do (I only tune local cars), I respect the amount of experience and judgment that a successful e-tuner acquires.
Drives: 2013 Black FR-S
Along the same lines, why did my IAM drop from 1 to 0.39 over the span of 2 weeks of daily driving (myslef in economy mode - no heavy foot)? During daily driving I get almost no knock correction (-0.7 being the max I saw once in a blue moon). Does the IAM decrease for other reasons than knock? Is there a "bad spot" in the tune in the low rpm zone that is triggering the IAM to decrease?
After realizing it was so low today, I did some aggressive driving (lots of high load/high gear/uphill/boost) on the way to work and saw it slowly crawl up to 0.50 by the time I got to work. Will see if I can get it to crawl up to 1.0 later today after work. Does anyone know why this happens? @DeliciousTuning @jamesm @mad_sb
#10 | |
Drives: car
#11 | |
| The Following User Says Thank You to jamesm For This Useful Post: | mizzta21 (07-10-2019) |
#12 | |
#13 | |
http://www.ft86club.com/forums/showp...2&postcount=56 |
| Safe to run 5w-30 oil? | NON-VTEC | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 47 | 03-12-2017 12:01 AM |
| Safe to use DOT 5.1? | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 10-27-2015 03:32 AM |
| Are these safe? | mrlewistan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 03-22-2013 04:22 PM |
| Be Safe! | Mr. J | BRZ First-Gen (2012+) — General Topics | 21 | 11-21-2012 05:46 PM |
| Safe to wax new car paint? | Nitro | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 06-09-2012 01:08 AM |
