Old 11-21-2015, 03:25 PM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
ABS and Traction Control Light on -> ABS Actuator Went Out
Has anyone else had their ABS Actuator went out? I recently had my brake fluid flushed and I'm not sure if that caused an issue to this.
I found this thread about it and that's about it:
http://www.ft86club.com/forums/showthread.php?p=1861750
Currently my car sits at Longo Toyota awaiting for an ABS Actuator...
Obligatory Car Towing Post.
I think this car is a trap... Second major failure this year....
First major failure -- Feb 2015
http://www.ft86club.com/forums/showthread.php?t=81496
Aside from that...I think this is a sign to get into another car
N1rve
Last edited by N1rve; 12-03-2015 at 11:51 PM. Reason: Apparently people are having this issue.
Old 11-21-2015, 04:04 PM   #2
ryoma
ryoma's Avatar
damn that sucks, hang a rabbits foot under your rear view or something lol
Old 11-21-2015, 04:29 PM   #3
N1rve
N1rve's Avatar
Poor rabbit
N1rve
Old 11-21-2015, 07:18 PM   #4
FirestormFRS
Brakes and fuel systems are the most engineered parts of any car. I would venture a guess that the fluid flush caused it.
FirestormFRS is offline   Reply With Quote
Old 11-21-2015, 08:33 PM   #5
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Jw how could flush cause it? I know not same but I flushed my trucks radiator and it would overheat for a min or two before going down to normal temps. Now it's all normal.
Packofcrows is offline   Reply With Quote
Old 11-21-2015, 08:43 PM   #6
N1rve
N1rve's Avatar
I have no idea
There could be air bubbles in the system or your thermostat kicked the bucket.
N1rve
Old 11-23-2015, 11:52 PM   #7
N1rve
N1rve's Avatar
Update:
Car was repaired.
They pulled the following codes:
P0700
U0122
C1241
C1294
The main issue was C1241.
They replaced ABS Actuator Assembly (896051) and H/U ASSY VDC SU003-04300.
N1rve
Old 11-24-2015, 01:56 AM   #8
humfrz
Oh, my, Packofcrows ......now THAT is some analogy ......
humfrz
Old 11-24-2015, 01:59 AM   #9
humfrz
Originally Posted by N1rve View Post
Update:
Car was repaired.
Well, now, N1rve, that was a bummer.
Glad you got it fixed.
I don't reckon it would take much misplaced air in the system to freak out the brake electronics.
humfrz
Old 11-24-2015, 06:32 AM   #10
steve99
Update:
Car was repaired.
P0700
U0122
C1241
C1294
humfrz
Weird, all those codes relate to electical issues
brake switch communications between modules
short to ground on abs module
unlikey it was mechanical issue or due to brake bleed flush.
likely module electrical issue, hopefully its sorted could have been due to dying battery or some other weird electical issue.
Old 11-29-2015, 08:16 PM   #11
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I had this come up once, erased the code and never came back. Got me thinkin' now
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 11-29-2015, 08:35 PM   #12
N1rve
N1rve's Avatar
N1rve
CEL P0020 - "A" Camshaft Position Actuator... raul Issues | Warranty | Recalls / TSB 5 11-28-2017 03:55 PM
CEL P0020 - "A" Camshaft Position Actuator... raul Tracking / Autocross / HPDE / Drifting 7 09-25-2017 03:01 PM
Clutch actuator position? Kiske Engine, Exhaust, Transmission 1 03-27-2015 05:43 PM
