Old 03-26-2015, 07:51 PM   #1
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Clutch actuator position?
Hi guys can anyone take a quick look at their clutch actuator (on top of the transmission housing, behind the engine cover.) I cannot for the life of me remember it the pluger went through the hole on the backing plate or was just supposed to rest on it. I think this may be why I'm slipping in higher rpms after swapping my clutch. Not engaging fully.
Thanks.
Old 03-27-2015, 05:43 PM   #2
wu_dot_com
Drives: accord
the actuator is called slave cylinder. the plunger should make contact to the clutch fork. the clutch fork is what moves the throwout bearing that actually depress the diaphragm spring to get the pressure plate to brake contract with the clutch disk.
hope this help.
wu_dot_com is offline   Reply With Quote
CEL P0020 - "A" Camshaft Position Actuator... raul Issues | Warranty | Recalls / TSB 5 11-28-2017 03:55 PM
CEL P0020 - "A" Camshaft Position Actuator... raul Tracking / Autocross / HPDE / Drifting 7 09-25-2017 03:01 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
