Old 10-23-2015, 05:30 PM   #1
ChrisP
TRD Lowering Springs Camber.
About a week ago I installed the TRD lowering springs on my 2013 FR-S. When I went in to get an alignment done today the left rear camber was at -1.5 degrees and the right rear was at -2.6 degrees. I understand that dropping the car an inch will add negative camber but it seems odd that the right is 1.1 degrees off from the left. anyone have an idea as to why this would happen? for what its worth the front left is -.1 and the front right is -.4
ChrisP is offline   Reply With Quote
Old 10-23-2015, 05:39 PM   #2
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
I'm sure others will chime in, but I believe this is just a matter of how the springs settled and how they were installed. This is why you're supposed to get an alignment as you have done after swapping out suspension components.
Toyarzee is offline   Reply With Quote
Old 10-23-2015, 05:41 PM   #3
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
I have TRD springs and I just recently got an alignment to get the tow and such all corrected. After everything was said and done I was sitting at -2 degrees camber on both of the rears. The front had less than 1 degree on either side if I remember properly.
Was the alignment guy able to correct the camber at all? When I went in they told me that it was not possible.
kuczynskika is offline   Reply With Quote
Old 10-23-2015, 05:41 PM   #4
vroom4
2.6 something may be wonky, worth checking the install. Highest I've heard of is 2.1 or so.
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
strat61caster (10-23-2015)
Old 10-23-2015, 11:01 PM   #5
ryan t
Drives: frs
Mine ended up similar, 1.7 lr and 2.5 rr
ryan t is offline   Reply With Quote
Old 10-23-2015, 11:27 PM   #6
ryoma
ryoma's Avatar
do you know what your stock alignment was? it might have been off from the factory. my stock camber was pretty even at -1.3 both sides in the rear. I don't know how you would find that much of a difference by just swapping out springs, unless you didn't seat them correctly on the perch
Old 10-24-2015, 04:31 PM   #7
ChrisP
Same here. I went to Les Shwab and they said it was non adjustable. So I'm currently in the process of looking for new lower control arms so I can adjust it.
Old 10-24-2015, 09:09 PM   #8
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Mine was dead on -2 on both sides.
Createddeleted is offline   Reply With Quote
Old 10-26-2015, 12:48 PM   #9
ChrisP
Could curbing the rear wheel throw the alignment/camber off? When I bought the car the right wheel was scratched and the tire had a chunk taken out. No damage to internals just looked like somone rubbed a curb pretty good.
Old 10-26-2015, 12:53 PM   #10
vividracing
vividracing's Avatar
I don't think the wheel itself would cause a camber issue, but maybe the previous owner bent something in the suspension when he/she curbed the wheel. Worth looking into...
-Seth
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
wparsons (10-26-2015)
Old 10-26-2015, 02:21 PM   #11
ChrisP
-Seth
Thanks for the heads up.
Thinking about lowering and camber adjustment, recommended shops in PDX? Llilith Northwest 4 09-08-2015 11:36 AM
What is needed for a proper alignment after lowering 1in? LCA's, Camber bolts? CallmeDave Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 05-17-2015 09:26 PM
Lowering - best way to adjust camber? _frs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-28-2014 04:35 PM
Rear camber after lowering mike_ekim1024 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-09-2013 04:01 AM
